Question about Samsung HCL4715W 47" Rear Projection Television
Samsung model PCJ22R 52'' will not turn on
TV CUT OFF while watching.unplugged and plugged back in .nothung happend
5 Related Answers
MICHAEL MULLINS
  • 927 Answers
SOURCE: samsung 52" tv
HEY,
Electrical storm, water and the TV does not work?
Well I'm here to give you help......
First find the source of water and fix that. I don't think there is any thing you can do but call a Samsung factory authorized dealer and have them give you an estimate.
The TV you own is selling for under $900.00, so be careful, it may not be worth repairing.
Posted on Jun 11, 2008
Anonymous
  • 1056 Answers
SOURCE: Samsung Rear Projection 47" TV goes into stand by on start up
I am sorry to disappoint you but a TV problem can only be fixed by electronic technician. If you want to do it yourself, you would have to learn electronics. Start by learning basic electronic, and then read a book on how to fix televisions. Without knowledge in electronics, you won't be able to understand a book on fixing a TV. I have been fixing TV since 1998, and I started after dropping out of electronic engineering class. I learned most about electronics on my own, and you can too.
Posted on Jun 27, 2009
dick davis
  • 610 Answers
SOURCE: 52' samsung pcj522r won't turn on.
have you replaced the lamp yet? other things that cause ttat are the ballast,cooling fan or power supply board. call1-800-samsung for nearest service center.
Posted on Nov 25, 2009
Anonymous
SOURCE: Samsung Model TX83082WH
need the spliter tu025
Posted on May 04, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: my 67" samsung tv work well when its on but when you turn off tv and turn back on you get sound and no picture unplug tv and plug in again picture come back on
First thing I would try is to remove set and a box or receiver if used from power for a while and then plug all back up--should reboot all units that way--cannot hurt and may very well help. Not just the set but any unit between signal source and set.
It might also be a good idea to see if when the screen is black if the lamp can be seen--is it on or not?
Posted on Dec 12, 2012
Will not turn on
Try unplugging it for ten minutes, then plug it in and try again.
Apr 12, 2014 | Samsung Televison & Video
I have a 52"
Need model number and blink code at time of defect.
Feb 16, 2011 | Panasonic Televison & Video
50 inch samsung wont turn on standby continues to blink
Try unplugging it from the wall for 5 minutes and plug back in .. let me know what happens
Jan 03, 2009 | Samsung DLP HL-P5663W 56" TV
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
No power
Good Day, jennylo04;
You need help??? I need help, too!!
Please help me by providing a MODEL NUMBER. OKAY??
Thank you, big IRISH,.
Aug 07, 2008 | Televison & Video
No Sound
Ok have you go into your audio menu and check them. make sure that the amplifer is set to internal and not external. and the speaker are on... you could have a blown audio output ic.
Feb 10, 2008 | RCA HD52W58 52" TV
Samsung HDTV 52" Flat Screen
Sound like the power supply with a bad capacitor.
Dec 13, 2007 | Samsung SP42P2S Television
My samsung projection television model pch521r wont stay on
when the set does come on do you notice any thing odd in the picture or sound of the set.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Tv wont stay on
Check for CRT coolant leak on PCB.Clean spill, try again to verify.
Samsung HCL4715W 47" Rear Projection Television Logo
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
