When i put cd's in the cd player they won't play and E 20 shows on the screen. what should i do?
SOURCE: cd stack in cd player,screen shows err
My CD Player did the same. It showed an "ERR" message when trying to detect the beginning of a CD. I thought that the CD was dirty and wiped it down. Then I discovered that the player would detect the CD when the car was idle, but not when the car was in motion. Maybe the laser is THAT sensitive. Hope this works for you.
SOURCE: CD player in 05 chevy cavaliar shows ERR what can
you have a cd driver error and it needs to be repaired or replaced. repairing it is cheaper, and the cheapest solution, Our shop repairs these unit on a regular basis. If you replace it with another factory unit you will have to have it programed at the dealer for it to work. Aftermarket radio will require some skill o install. modules and accessories will need to be purchased. Not sure where you are but our shop is in Oshawa Ontario.
SOURCE: My radio/CD player constantly says
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
