Question about Metra Car Audio & Video
94 Hino GH super eagle, no headlights, no wipers, no exhaust break, no break lights
1 Related Answer
Bill Boyd
  • 53816 Answers
SOURCE: Hino 1991 GH Supereagle 9 speed Eaton High range won't shift to low range any help would be appreciated
the low speed piston is not moving
could be dry and need lubrication
possible probble in the button , not allowing air pressure past when you select the low range
check for blown plastic line from button to box
Posted on Mar 18, 2018
Mar 18, 2018 | Cars & Trucks
My 94 eagle talon bogs down when I try to take off fast why
Could be a a clogged injector or fuel filter. Fuel filters are cheap to replace, a quality injector cleaning is around $120. Do you have check engine light on, if so I bet there would be a faulty o2 sensor, this causes the exhaust system to read excess fuel in exhaust and refuse to allow more gas through.
Jul 08, 2013 | Cars & Trucks
What is the 94 Chevy Caprice Classic wiper arm
heres a wiper linkage asm diagram, the wiper washers are on the hood or on the cover to deck,then the hose runs through the wiper arm to a nozzle, if you remove the arms you can lift cover enough to look at the hose to washer connection,also check hose to arm they often break there good luck.2d8c418.gif
Mar 30, 2010 | 1994 Chevrolet Caprice Classic
Head light wiper does not work
These motors break all the time, and they are expensive to replace. Most people just unplug the motor that is affected, and loosen the wiper arm to reset it to a 'rest' position. After that it all looks normal
Jul 16, 2009 | 1998 Volvo V70
How do you turn on the headlight wipers in a 94 E class
You have to have the headlights on for the headlights wipers to work.They don't work with the headlights off.
Feb 01, 2009 | 1994 Mercedes-Benz E-Class
Car Audio & Video Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
