GE JVM1190 Microwave Oven Logo
A
Anonymous Posted on Dec 19, 2013
Need to replace fuse on jvm1190by002 ... - GE JVM1190 Microwave Oven
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
How do I replace fuse
Well you need to find where the fuse is located, And determine what type of fuse is being used. So you know what fuse you need to buy to replace it.
How do you know you need to replace the fuse?
Replace fuse Kenmore 40188523011
If you know that a fuse is open, you need to find out why it went out before replacing it. There are typically three fuses in any given microwave oven. Line or monitor fuse, cavity temp fuse and magnetron temp fuse.
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
No power
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
1helpful
No power on the microwave
HI, there is an in line fuse located on the Ac power cord near the power supply inside the microwave. Check to see if the fuse is blown. replace the fuse if needed. Now, if the fuse is in good condition, this will confirm power board failure. you will need to replace the failed component or replace the entire power assembly in this case.
5helpful
NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
NEED OPERATION MANUAL FOR 1998 MICROWAVE-CONZECTION OVEN mODEL JVM1190BY002
Go to geappliances.com. Select "Use and Care Manuals" under the Search drop down menu. Type in your model number in the adjacent window and select "Go". Your manual is available in a downloadable .pdf format. I hope this helps you.
GE MICROWAVE FUSE REPLACEMENT
i have a galanz microwave i need to replace the fuse and i dont know wht to buy
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
