RTO 1 Siemens Pure 500 Open Fit Hearing Aids Aid Ric Bte Logo
A
Anonymous Posted on Dec 19, 2013
Need ear piece for Siemens Pure 500 - RTO 1 Siemens Pure 500 Open Fit Hearing Aids Aid Ric Bte
4answers
2helpful
How to clean the domes on hearing aids
Take the domes off, wash them out or use a pipe cleaner to poke out the wax. If you have washed them, make sure they are thoroughly dry before you put them back on. When you put them back on make sure they are firmly on the receiver tip or you will be taking a trip to A&E to get it removed from your ear canal.
R. Hearing aid has died for the 5th time. Purchased through HearX.
RIC instruments are quite delicate, the receivers often fail, however it is a quick fix to replace them. Have you tried a drying kit, a drying kit is essential to maintain RIC or RITE instruments particularly during the summer months. Go back, get the receivers changed and ask for a drying kit.
3helpful
Siemens charger for hearing aids starts charging and then after some hours one light goes red
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
1helpful
It's exactly like the guy says on the left: Siemens Pure 501 RIC Serial No RW52119 The above unit is in the right ear and periodically does not produce any sound. The RIC cord has been replaced once and...
The receiver, the piece you call the cord is either blocked with wax or dead. Check the very tip of the receiver for wax detrius, if there is some remove it and see if you can hear. If not you may need to get a new receiver.
Siemens Pure 501 RIC Serial No RW52119 The above unit is in the right ear and periodically does not produce any sound. The RIC cord has been replaced once and still the problem persists. Pushing...
It could be a receiver issue, the cord, it might be a faulty receiver or alternatively it could be plugged with wax or badly affected by moisture. Receiver issues are relatively common with Siemens, if you have cleaned out the tip and are confident it is not a moisture issue, the receiver has failed. it is an easy fix and your audi should be able to change it out on the spot.
2answers
I find that my BTE open fit hearing aid solves a lot of problems but the fitting seems to creep away from the ear drum making it difficult to hear. I find I am continually pusshing the tube back to where...
There are a couple of solutions that you can try, ask your audi to fit a sport lock or change the tip he is using. If that does not work, think about investing in a set of custom made tips. A sport lock is a piece of plastic that attaches to the tubing, when you place the tip in your ear this piece of plastic is folded around the inside of your outer ear along the bowl.It aids retention of the tip.
I have Pure 700 RIC BTE HAs for 14 months now. I have had 8 repairs to date. Seems any perspiration ruins the amplifier. I keep them in a drier overnight. I paid a lot of money for them and they are " In...
It is a common problem, Siemens do seem to suffer it more though. Your audi should keep receivers on hand in order that he can fix it on the spot. Keep your ears clean and dry, clean and dry your aids every night. The use of a drying kit is ideal, but make sure you are changing your tablet enough or re-charging your crystals in the microwave, whichever it is.
1helpful
Can come out when i remove glsses or take off jumper or hat
Hi Jan3630,
The instruments you show in the picture appear to be ear inserts rather than custom ear mold. Customs can also be small.
You may consider having a local Hearing Health Care Professional advise you as to the feasibility of replacing your sound tubes and inserts with Custom ear-molds.
These will have a better chance of staying in the ear when you are doing the activities you described. Please advise if you find info helpful. Thanks for contacting FixYa.com
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
