Paper jam error
Please, we just set up this fax and after few minutes it started bringing paper jam error of which there is no paper anywhere inside the machine. We replaced this with another and that has been working since. We purchased ten (10), eight (8) are still in store, one is working now while this particular one that is faulty is what we want to resolve.
Posted by Asseteam on
  • karlak Jan 12, 2008
    the paper goes into the machine approx 1/3 of it then jams. i have checked both inside and out and have found nothing. it seems to jam at the beginning of feed. aslo will tell me to load paper when paper is already loaded.
  • Anonymous Aug 13, 2008
    Are Muratec F-300 has a paper jam message we have taken out the paper tray the toner and drum we can not find any paper at all.The machine still keeps displaying the paper jam message
Soulvisitor
  • 1,113 Answers
Check rear door for paper fragments check paper jam sensors ussally one front middle and rear make sure they arn't stuck, model make?
Posted on Oct 16, 2007
skil router table assembly instructions
    Problem Solver:
Hello
I have a Brother 290MC thermal paper fax phone. I was receiving a fax and the paper jam. I was removing the paper and a small piece of it stuck inside of it and it is too small to see to remove. I'm not sure how to take apart this model to remove the paper. Could someone tell me how to take it apart so I can remove the paper?
Thank you.
Cilla.
Posted on Aug 18, 2008
Why am i getting the error message * memory rx 2P Recording Paper Jam? I can t find a jam anywhere?
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 27, 2014 | MinoltaFax 2600 Printer
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
P2015dn paper stops in the through-output path with approx one-half to one inch of paper projecting. Jam indicator lights. Removing paper shows printing has completed over full length of paper.
please, gradually pull out the paper, off your printer and clear the scheduled print jobs through control pane-printers and faxes-select your printer to open then select all the jobs in it and cancel/delet, please before you on and start using make sure the papers in the feeder are aligned and fits the tray i mean set the tray according to the size of the paper, one minutes u can now on and start printing it will work 100% i use the same printer.
Jul 19, 2009 | HP LaserJet P2015 Printer
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Lexmark F4270 Paper Jam Problem
Go to the menu and make sure it is set to Letter and not Legal size.
Oct 29, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
331 people viewed this question
Marvin
Marvin
