SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
SOURCE: Memory card error - can't format card
Can you use the card in another device? Can you access the card un a USB card reader? If so, it is possible that the camera cannot handle a card that big. You would need to check the manual to see that it can handle a 4Gb card.
SOURCE: Canon powershot SD1200 IS says Memory Card Error
You probably just need to format the card in the camera. This will completely erase it so download any pictures you want to save first.
SOURCE: memory card error powershot Sd800 IS
Take out your memory card from the camera and then
inspect a small or tiny switch. This is the card lock. You need to move
it the other way around to enable write back on the memory card.
Hope this helps you out.
SOURCE: brand new canon powershot sd1400
You need to go to the menu screen, scroll over to the tools option, scroll down to format and format the memory card. I just had this same problem and this is what worked for us!
