Question about Pioneer Car Audio & Video
Pioneer Radio in 95 Ford F-150 doesnt produce sound
My pioneer radio unit powers up but does not produce any sound. As an experiment, i plugged the radio in a friends car and everything works fine.I think its the wiring. What wire would cause no sound to be produced to any of the four speakers? Any ideas?
Posted by jimmy delano on
5 Related Answers
mixmaster
Timothy D
  • 626 Answers
SOURCE: fitting a pioneer stereo
You did not list a year for your vehicle.
I get most of the wiring diagrams from here;
http://www.the12volt.com/Default.asp?
Best of Luck.
Posted on Nov 18, 2007
Anonymous
SOURCE: Pioneer DEH-9600: No power to rear screen
bad ribbon cable
Posted on Mar 25, 2008
julian appleby
  • 149 Answers
SOURCE: Remove Pioneer radio from dash
Try ebay:
Item number: 370036329272 rtcurve.gif
If the facia comes off, remove it and you should see two vertical slots. Insert the keys and pull out the unit. Disconnect the plugs for speakers power and ariel.
Posted on Mar 26, 2008
Shdak
Mike Abrams
  • 23 Answers
SOURCE: what is the speaker wire color code for pioneer
Crutchfield has allot of information on Pioneer receivers. They also have a number you can call for support. The wiring diagram can be found here: PDF File
Posted on Apr 06, 2009
Anonymous
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
Why pioneer 150 mp radio installed but shows no display at all ?
have you verified it has power to the radio and that it has a keep alive memory power source
Oct 15, 2016 | Pioneer Car Audio & Video
How to fix radio in 2004 durango radio won't play if i start engine without waiting for sound before i start engine. Now my daughter plugged her ipod in without waiting now it does't work at all
My suspicion is there is an issue with your vehicle's electrical system or the radio is poorly wired. It should not matter at all whether the radio is playing or not when starting the vehicle. If, while starting, your alternator is kicking out too much voltage, this could possibly put the Pioneer into protected mode meaning it would produce no sound.
I suggest having someone connect a DMM (Digital Multi-Meter) to the battery while you're starting the vehicle and see what voltage it's producing. It should be somewhere between 12-14 volts and after starting, be no higher than around 14.8 volts. If it is higher, get it checked by a mechanic.
Dec 22, 2013 | Pioneer Car Audio & Video
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
I shut off my car and turn it back on i need to setup the radio and my settings again it doesnt save ! im missing the orange wire for illumination but my deck still illuminates its the memory thats doesnt...
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
Sep 08, 2011 | Pioneer DEH-3400 CD Player
After reconnecting the car battery, the radio would not turn on
The pioneer has a small protection fuse in the back of the radio, alot of time when it catches a power spike, it will blow to protect the head unit. It should be plugged in the back of the radio under the main plug. Hope this helps.
Aug 20, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
Pioneer head unit plays in accesory mode, but not when vehicle is fully started
he tapped into starter wire instead of accessory. Remove radio and verify the switched power (red) wire is properly hooked up to an accessory wire that stays on after vehicle is started.
I believe the wire is white/black behind the radio. Check with a voltmeter to be sure.
http://www.the12volt.com/installbay/stereodetail/967.html
for the wire codes to that vehicle.
Oct 18, 2008 | Pioneer DEH-P3700MP CD Player
Try ebay:
Mar 26, 2008 | Pioneer DEH-P5800MP CD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
83 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
