Guest access cisco connect
All of the sudden my iphone can't connect to my computer router, WHY? And it keep telling me my password is incorrect for guest access, WHY?
Posted by Jacqueline Hall on
Dan Castro
    Champion:
  • 329 Answers
If you give your password out indiscriminately, someone could get into your router and change the configuration (password). Not sure if this pertains to your router. Try to configure the router again and close down guest access until you can get a handle on who you can trust.
Posted on Jun 26, 2014
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
Posted on Oct 28, 2009
techjuli
Juli H.
  • 157 Answers
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Posted on Nov 30, 2008
Anonymous
  • 79 Answers
SOURCE: password reset of cisco 2800 router
Straight from Cisco:
Password Recovery Procedure for the Cisco 2600 and 2800 Series ...
Posted on Jun 11, 2009
Anonymous
  • 6 Answers
SOURCE: Cannot connect other devices to my router
You reset it to open, no encryption and it still didn't work? HMMM. You are able to get your PS3 online? but can't connect your laptop and desktop? Are you hard wiring the desktop to the router? or are you trying to connect it wirelessly? If you are configuring your router with either the laptop or desktop, make sure the IP settings on your connection manager are set to the correct domain under Local Area Connection Properties, like 192.168.1.226, or something similar. Login to the router with your admin credentials. Make sure in your configuration (as instructed in your manual) that you have the router time set correctly so the lease time for your devices aren't expired. Apply settings. After exiting your router configuration screen, go back to your connections manager, either wireless connection, or ethernet adapter in your network connections folder, and under the General tab of the Local Area Connection Properties, change the properties of your TCP/IP client back to "Obtain an IP Address Automatically." Click "Close" and your computer should show "Connected."
Posted on Feb 17, 2009
BearWeb
Dustin Ellse
  • 357 Answers
SOURCE: I want to connect my Iphone to my wireless
First of all you will have to configure your router to accept the iPhone. To do this you will need to go in to the router in your browser window and add your new device, it will ask you for your MAC number which can be found under the back cover of your iPhone or in your WIFI settings.
Then you will need to configure your router to either automatically assign an IP Address or use an allocated IP Address and use the same setting on your iPhone. Also, you will need to configure your router to either assign a DNS Server automatically or to use an allocated DNS Server and once again you will need to use the same settings on your iPhone.
Your IP Address is crucial in oreder for your iPhone to connect to your wireless network. Your DNS Server is crucial in order for your iPhone to access the internet through your wireless network.
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Posted on Jan 01, 2010
How can I set up a guest access
Have you installed Cisco connect software on the main computer? You will find gust network settings on Cisco connect software. Or you can open the setup page and check the wireless settings.
Check this link for guest network settings. i hope this will help you.
Cisco Guest network access for Linksys routers
Oct 08, 2015 | Linksys Cisco Wireless Router E1000...
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
How can I remove my neighbor from my network
Easiest thing to do, Change the password to your router. Once this is done, it will prevent your neighbor from any further access to your router and of course prevent internet access. Most all routers are simply a local web address for access. Example: 192.168.1.1 typed inside a browser address pane will take you inside the router. Check your router for setup procedures.
Have a great night..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Sep 09, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
Password for guest Cisco connect
For me I am using my laptop and my laptop call Toshiba what can I do make my internet on for good cause it tell me that I have to enter password for Cisco quest access
Aug 18, 2014 | Computers & Internet
Guest access password from Cisco connect
You'll need to log into the router, address is most likely 192.168.1.1 it will ask for your email address and password do that. Then go to guest access.The password will be listed there
Jul 26, 2014 | Computers & Internet
Forgot guest pw on cisco e2500
If a password was set by user, no one else will know it if you forget it.
If the password needs to be reset to factory, so you can log in with the "default" password AND RE-SETUP EVERYTHING, then you'll need to reset the Linksys E2500 to factory defaults. You can usually do that via a special button or sequence of actions.
The E2500 manual will have specific directions for performing a factory default reset. You can download the manual for the E2500 from http://support.linksys.com/en-us/support/routers/E2500
Aug 08, 2013 | Linksys By Cisco E2500 DualBand WirelessN...
Why is Cisco router not giving internet access to guests
I'll venture a guess that some file sharing or such activities are going on, using up the three guest IPs. I'd suggest upping the number of guest access in the router to something like 10, then taking it down from there. Perhaps don't broadcast SSID if you want to ensure someone is leeching your internet bandwidth, and share the name (SSID) only with your friends/guests.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Want to put lock on guest
Linksys E series routers can broadcast 2 wireless networks. First one is the main wireless network which is secured wireless network.
The second network is a guest network which will always show you unsecured.
It will never show you secured and you can not make it secured.
However it has a web based security.
Anyone can connect to the guest network but will not be able to access Internet without Guest access password.
In other words there is a security.
You can disable guest access also.
See more about Cisco Guest network access password
Mar 10, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Password for guest access
What is the model number of your router? If you have installed the Cisco connect on your main computer then you can find the password for the guest network on Cisco connect software.
You will need to heck the Cisco connect software to find password for the guest network
Dec 08, 2011 | Linksys Computers & Internet
I do not know my guest password for my router so my guest cannot get on the internet using my router at my house
on the bottom of your router is an ip address: usually, 192.168.1.1
enter this into the search bar of your computer.
the router settings page will come up. the user name is: admin
the password is: admin now you can set the guest password and, configure your router.
Jul 16, 2010 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
154 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
