Samsung SyncMaster 910MP 19" LCD Monitor Logo
S
Sabine Guerry Posted on Nov 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thin vertical colour lines on half of the screen
The screen flickers a bit when I plug it in. Sometimes, the image is perfect. But then, half of the screen becomes thin vertical colour lines. If I unplug and replug the screen, or change the definition of the screen, it may get back to a good image for a while, and then the problem starts again. What is the problem here please?
Tyson
Level 2:
Habit-Forming:
New Friend:
  • Expert 73 Answers
  • Posted on Nov 15, 2017
Tyson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
73
Questions
Helped
19690
Points
276
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Aug 06, 2006
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Anonymous
  • 163 Answers
  • Posted on Aug 11, 2006
SOURCE: Scrambled Image at random intervals
it sound to me like a power supply problem, but in this tv most be a ribbon cable one, any way you need a tech, regular people cant do nothing in this case....good luck
Anonymous
  • 624 Answers
  • Posted on Feb 09, 2007
SOURCE: LCD 19" Samsung - one half od display has yellow vertical lines
Vertical lines are typical of LCD panels that have failed. I would certainly try the monitor on another machine; however, if the problem follows the monitor this is probably going to require some repair work. Unless you have the tools and skills to work on fairly delicate and potentially dangerous components this will be a job for an authorized repair shop. If you have any more questions let us know otherwise please don?t forget to rate this post.
Anonymous
  • 231 Answers
  • Posted on Dec 23, 2008
SOURCE: color and other problems with SyncMaster 910 MP monitor
Go to => http://www.samsung.com/us/
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
adrian halligan
  • 1075 Answers
  • Posted on Feb 15, 2009
SOURCE: daughter sprayed water on samsung lcd 32 inch on the front panel
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
1helpful
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Led problems
Why do I have a green line on the edge of my screen? If you have a thin green line on the edge of the screen when using an HDMI cable to connect to a cable or satellite box this is usually caused by the box.
To test to see if this is a box issue you will want to take the following steps:
If the TV has a Horizontal position setting in the menu you can adjust the position to see if the line disappears.
You can also change the Wide setting to the Zoom or Panoramic option to see if the line disappears.
If the line disappears you will want to look into getting a different source box.
Your display may be flickering for several reasons. You will want to take the following steps to rule out the most common reasons for the display to flicker:
1. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them.
2. Check your Advanced Video settings in the Vizio TV menu some of our Vizio televisions will allow you to adjust the following settings under the Advanced Video settings:
Ambient Lighting
Backlight Control
Advanced Adaptive Luma
If you have any of these options available please turn all of them off to see if this resolves the display flickering.
If the above steps have not resolved the issue please take the following steps in the order presented:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There is also a factory reset option in your menu under the SETUP section. It will say either "reset all settings" or "system reset". We recommend that you reset all settings as well to see if this resolves the issue. If this does not resolve your problem please contact our technical for further assistance.
If the line stays in the same spot when changing the above settings please contact our technical support.
My Packard Bell (bought May 2010 new) laptop has a screen flicker problem. For the past week, every now and then the left half of the screen, or sometimes the bottom half of the screen, gets distorted with...
<font size="3"><i><span style="FONT-FAMILY: Arial; COLOR: #cb0101" lang="EN-US">4400mAh, 11.10V</span></i><span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"> Dell Vostro 1710 Battery Replacement<span style="mso-spacerun: yes"> </span></span></font><span class="redfont1"><b><span style="FONT-FAMILY: Verdana; FONT-SIZE: 16.5pt; mso-bidi-font-family: Arial" lang="EN-US"><font color="#cb0101">$ 72.58</font></span></b></span><br /> <span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"><font size="3">Dell Vostro 1710 Battery</font></span><br /> <span class="htmlval1"><span style="FONT-FAMILY: 'Courier New'" lang="EN-US"><font size="3"><font color="#0000ff">Discount Dell Vostro 1710 Battery 11.1V 4400mAh,fit for Dell Vostro 1710, Dell Vostro 1720 Laptops.Full 1-year warranty and 30-day money back!</font></font></span></span><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">ShippingArea:</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #cc0000; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">We ship all over the world!</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US"></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Brand :Dell Vostro 1710</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Type :Li-ion</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Voltage :11.10V</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Capacity : 4400mAh</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Ltem(Cell):6-cell</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Color :Black</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Dimension :270.90 x 50.00 x <st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="20.2" unitname="mm">20.2mm</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Weight :<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="665" unitname="g">665g</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery SKU :DE017K</span></b><br /> <span lang="EN-US"><a href="http://www.battery-sale.net/dell-vostro-1710-battery.html">http://www.battery-sale.net/dell-vostro-1710-battery.html</a><span style="mso-spacerun: yes"> </span></span>
Thin vertical line that is multi coloured
hi
just clean the 15 pin connector in the cpu end
2answers
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
2answers
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
