Question about Xitel INport Deluxe for PC
LP recorder incompatibility
Unable to install LP recorder on new CP windows 8, it reads " error LP Recorder has terminated. Soundcard recording device not found (004F4464) thanks.
Posted by Lindey Del Aguila on
windsorguzzi
    Master:
  • 796 Answers
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Posted on Dec 19, 2013
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
0047BB69 with the LP Recorder
This is not a solution. i have just discovered that I have exactly the same problem.
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
My computer does not recognize ny recorder as an external device
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jul 03, 2009 | Olympus VN-4100PC Digital Voice Recorder
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
12. Click Next
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
Digital wave player wont pick up recorder when i plug it in
12. Click Next
Apr 02, 2009 | Olympus VN-4100PC Digital Voice Recorder
Drivers for Olympus VN-4100PC Digital Voice Recorder.
12. Click Next
Mar 23, 2009 | Olympus VN-120 Digital Voice Recorder
I cant transfer files from recorder to my pc
12. Click Next
Mar 12, 2009 | Olympus VN-4100PC Digital Voice Recorder
Do you have the downloads for vista yet?
12. Click Next
Jan 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
Driver for VN-1100-PC
Olympus has provided new software for VN recorders to used with VISTA plus a few updates.
Uninstall the Digital Wave Player
Uninstall the recorder in device manager
Download and install the New digital wave player,
olympusamerica.com/files/digitalwaveplayer.zip
then go to Olympus america and download all VISTA related updates. Once you have installed and updated the Digital Wave Player software, plug in the recorder and Windows will use the Olympus Driver (not digitally signed) to install and the Digital Wave player software will open automatically.
Feb 22, 2008 | Olympus DS-2300 Digital Voice Recorder
Xitel INport Deluxe  for PC Logo
346 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Bill Boyd
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
