SOURCE: New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
SOURCE: oki 5500 n
You cant do it via admin code or software.
Inside every part is a little green picofuse.
When the printer starts, it looks for continuity. If present, it burns the fuse and resets the corresponding counter.
If you want to be creative, you can replace the little fuse. Easiest done in belt and fuser. Almost impossible in drums.
Or one might construct a little device with a fake fuse to insert between the part and the corresponding connector.
SOURCE: Oki b2540mfp fuser error. Is there a reset in
replace main board...thats what i had to do...
SOURCE: I have a Oki b6500. Replaced the fuser. How to
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
