Question about Drills
Circuit diagram bosch d70745 battrey charger - Drills
Posted by michael collier on
Hi I need circuit diagram refrigerator bosch model KSR38A0 tanx
Request the wiring diagram for model KSR38A0 directly from Bosch.
Apr 16, 2018 | Bosch Refrigerators
My pc has just stopped running the charger light is on but wont charge help
battrey his already damaged, try replacing them with new battrey ....
Jun 02, 2010 | ASUS Eee PC 1005HAPU17BU Netbook
Where can I obtain a circuit board for a bosch cordless drill charger, Charger is AL 2404, part number 2 607 255 185, also has D-70745 Leinfelden printed on charger
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Jan 13, 2010 | Bosch Drills
36 volt battery won't charge
Get a voltmeter and check for the output voltage of the charger. Should be greater than 36 volts. Also make sure that the voltage is getting to the battery via connectors. Just be careful around lithium batteries - they can blow up of short circuited!!!!!
Sep 14, 2017 | Office Equipment & Supplies
Battery charger does not work for my bosch hammer drill sds plus .. my dad is an electronics engineer and he requires the circuit diagram to investigate the problem, where can i get one for this model .....
My charger (24 v) died also and repair shop wanted too many $ for repair. I happened on-to a charger for a printer (24v 1 amp) at the thrift store for $3.00 and fashioned a connector for connecting to the battery. It takes about 3 hrs to charge the battery but you must disconnect manually. It has been working for many months. It will do for me untill i find a bargan on ebay. The repair shop said that the part that failed was not a component that can be changed. (Multyfunction chip) Hope this helps for the short term. Enjoy
Dec 14, 2008 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Help!
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
Dec 04, 2008 | 2003 Volkswagen Golf
Circate diagram
Hi,I just find the circuit diagram,hopefully that could help you ! :-)633a624.gif
Nov 21, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
133 people viewed this question
Top Drills Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Drill Expert? Answer questions, earn points and help others
