After a thunderstorm my 32" LCD does not have any colour. It is connected to a Dstv dual view decoder. The decoder lost the signal and did a re-scan. Tv1 now has no colour but Tv2 does. Another tv connected in place of Tv1 works perfectly.
Posted by Eric Jones on
Steve
    Problem Solver:
  • 11 Answers
Check the TV Standard
UK = PAL (i,c,etc)
USA = NTSC
Etc
You should check both the TV & your decoder box.
Posted on Dec 19, 2013
3 Related Answers
mahesh patel
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: Television cannot find channels in
It sounds like the Dish receiver is having a problem. Have you tried calling Dish to see if they can reset the signal to the receiver (the Dish box attached to the TV...)? If they do that and it still has problems they should replace the Dish Receiver at no cost to you.. That should resolve the issue.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 07, 2010
kukere
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
How do I clear error BEi or BE1 on dual view dstv decoder.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/..
Aug 17, 2016 | Televison & Video
I have bought the old decoder and need to set up the satellite dish. I had signal for approx one minute, then lost it. What is the angles in azimuth and height to set up the dish?
The angle and azimuth depend on the position of the satellite. Contact any technician. Gopakumar Gopalan Google
It is not easy to predict the exact angle and azimuth. You should have a signal meter to proceed.
Jan 12, 2015 | Televison & Video
Dual view DSTV decoder stuck on scanning searching for signal
I Was watching generations all of a suddenly my decorder starts scanning continuosly
Mar 19, 2012 | Acer Aspire Televison & Video
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
TV says it does not support HDCP.
UNPLUG ALL CONNECTION FROM DECODER EXCEPT MAIN CABLE SIGNAL UNPLUG POWER WITH CABLE ONLY CONNECTED RECONNECT POWER WAIT FOR CLOCK TO DISPLAY HDCP SHOULD BE GONE RECONNECT ALL OTHER CABLES
May 28, 2010 | Olevia LT32HVM 32 in. LCD Television
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
