Question about Jura Capresso EspressoPRO 112 Espresso Machine
Bottom cover removal
A piece of rubber tube fell off and now the machine is working but is leaking. I can't figure out how to take out a bolt (shaft rather) on the bottom cover that in order to reach inside. It is just that tube that needs to be replaced.
Posted by nasko on
Anonymous
    Sergeant:
  • 274 Answers
Can you attach a picture of the bolt you speak of  Or the bottom of the machine?
Posted on Oct 20, 2007
  • Anonymous Oct 20, 2007
    The manual is not very informative.  A picture would help but also here is their customer service info:
    CUSTOMER SERVICE Hotline 1-800-767-3554
    Monday through Friday from 9:00 am to 9:00 pm E.S.T. and Saturday 9:00
    am to 5:00 pm E.S.T. If you call outside of these times you can always
    leave a message.
    Please note:
    Traditionally Monday AM is the busiest time and you might encounter
    waiting times of up to 10 minutes. However you can always opt to leave
    a voice mail message.
    EMAIL:
    [email protected]
    FAX:
    (201)-767-9684
    MAIL:
    Capresso Inc., Customer Service
    P.O. Box 775
    81 Ruckman Road
    Closter, NJ 07624
    Jura-Capresso LLC, Customer Service
    P.O. Box 775
    81 Ruckman Road
    Closter, NJ 07624
My 2006 Hhr rear passenger side leaks onto the seat when it rains.t
This is a rather common issue with these trucks...and rather easy to fix.
There is a piece of rubber underneath the front trim that covers a hole in the upper firewall. Over time, the adhesive that holds it wears out & it works like a funnel...directing rainwater directly into the cavity & down into the cabin.
Top repair, lift the hood, and look at the base of the windshield. You'll see the large plastic piece of trim that goes across the width of the glass. Remove the screws holding it in place & remove it..
Now you should be able to see the rubber sheet that I mentioned earlier. Looks like an oblong piece of inner tube. I got a piece of thin sheet aluminum, and used the rubber piece as a template to cut it to the correct size. Then I used some adhesive caulking to bond the rubber piece to the bottom of the aluminum piece. Then I caulked around the perimeter of the hole & installed the new cover...then reinstalled the trim.
Works like a charm.. Cheap to do...and is a pretty quick fix. Maybe an hour in total.
Mar 04, 2015 | 2006 Chevrolet HHR
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
PAV2300 agitator bolt keeps coming loose
Loctite sounds the order of the day. Don't overtighten once the thread lock is in place and allow to cure before using machine.
Apr 23, 2012 | Maytag PAV2300 Top Load Washer
I am trying to replace the starter in my 86 nissan stanza but cant see it
NISSAN STANZA WAGON - Manual Transmission
Q. Where is the starter on a 1986 nissan stanza station wagon and how do you get to it ?
Due to limited access to the starter, it is recommended that the transaxle be removed when servicing the starter.
REMOVAL:
1. Cold vehicle.
Remove 2 mounting bracket bolts, 10 & 12 mm (Figure 1).
Remove top starter motor bolt 14 mm with universal & long extensions.
Raise vehicle on hoist.
Remove front splash pans 10 mm.
Automatic transmission: Drain 2 qts out.
Remove rt-ft wheel 21 mm., & tie rod (Figure 3), axle cap, cotter pin, adj-nut & rubber washer.
Remove ball joint nuts 17 mm., left lower control arm 19mm. & swaybar bracket 14 mm. (Fig 2).
Remove axle nut 36mm (Figure 4), the front tube, catalytic converter heat insulators 10mm, ctr ex-tube 17 mm., and front tube from exhaust system (Figure 5).
Remove long bolt from ft engine mount (next to radiator), 17mm socket (Figure 6, Item A).
Remove tension rod mount 14 mm. Has adj-bracket with rubber insulators (Fig 6, Items B, C).
Remove right side drive shaft bolts that hold shaft to bracket mounted on engine (Fig7) 12mm.
Remove rt-driveshaft.
CAUTION: Transaxle side seals are cut by spline teeth.
Install hoist type transmission jack and wooden block under the transmission/engine. Be certain the transmission is safely balanced on the hoist.
Remove 5 engine crossmember mounts (3 bolts, 2 nuts) 14mm.
Remove nut that attaches crossmember to engine mount.
Loosen stabilizer bar mounts to allow adequate clearance for crossmember to be removed.
Remove following brackets to allow starter assembly to pass through bottom:
tubular support bracket - engine to transaxle
angled support bracket - driveshaft bracket to engine mount
manifold collector stay - (bottom bolts)
Loosen top bolts, remove bracket above driveshaft-holding bracket 14mm.
NOTE: This bracket is slotted to allow it to slide out without completely removing the bolts.
Remove bottom starter motor mounting bolt.
Separate starter assembly from bellhousing, DC all cables/connectors, remove starter motor.
When installing starter, connect cable, install/torque starter bolts.
Nov 03, 2010 | 1986 Nissan Stanza
My shift lever is loose on my F-350 Automatic, plus a piece fell out that keeps it from going into reverse.
shift shaft bolts under dash came loose the piece that fell out must have been a torx head bolt, look under dash follow column you will see where it ends at the bottom there is a bolt missing. could also be shift shaft bushings.
Aug 16, 2010 | 1996 Ford F350 Crew Cab
Our coffeemaker leaks water from the bottom while brewing
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 17, 2010 | DeLonghi BCO120T Programmable Espresso /...
How do i access the front heater core of a 2004 dodge grand caravan , steaming up window and looks like leaking on drivers side
Remove neg batt cable. Drain the cooling system. Remove radiator cap, set heater control to max heat. Drain coolant through valve on bottom rad of the radiator. 12 qt bucket. Pull the carpet out of the way on the driver side floor. Remove the bolts to the steering shaft coupler cover. Remove brake light switch from bracket. Diconnect the power brake booster pushrod. Place towels underneath around area for fluid drippings. Remove retaining clips from HC fittings. Pull the tube out of the HC & carefully rotate them out of the way, plug the open tubes for less mess. Remove the HC bracket bolts, then remove the braket. Push the brake pedal down , the gas pedal up & move the shaft cover out of the way. Pull the HC out of the heat/ac hopusing unit...
Dec 26, 2009 | 2004 Dodge Caravan
I have an oil leaks fgrom the tube that goes into the bottom of the oil sump. How do I fix it?
If you are referring to the tube that houses the oil dipstick it should be held in place with a small cap screw / bolt if you remove the tube you will find there is a rubber o ring remove the old and replace with a new one while you have it a part inspect the tube and make sure it is not cracked or broken befroe you install the new oring, if it is cracked or broken it will need to be replaced
Sep 26, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Jura Capresso EspressoPRO 112 Espresso Machine Logo
140 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
