Question about Sony VAIO FX150K Notebook
SONY VAIO VPCEH CLOCK LOSING TIME ON MAINS POWER
4 Related Answers
Faisal Khan
  • 674 Answers
SOURCE: sony vaio vgn-fs775p laptop real time clock not keeping time
Properly Configure Time Zone
Make sure that you have properly configured the time and selected the right time zone. Configuring the time zone properly may fix clock that keeps resetting. To do so follow these steps:
  1. Click on Start
  2. Open Control Panel
  3. Click on Date and Time
  4. Click on Time Zone
  5. Select the right time zone by clicking the arrow below
  6. After selecting time zone don't forget to click "automatically adjust...."
  7. Click OK
Check CMOS Battery
There is battery named CMOS on the motherboard, if this battery becomes dead PC loses its date and time settings. Problem in battery may result in this issue. Replacing the battery with a new one is the best solution to fix the problem.
Install Windows Update
Some of the Windows updates also contain a patch to fix clock keeps resetting. To download and install latest Windows updates follow the steps below:
  1. Click on Start and open Control Panel
  2. Locate and click on Windows Update
  3. In the right panel click on Check for Updates
  4. Install the Updates
  5. Restart your computer
Repair Windows Registry
Mostly PC problems occur due to corrupt Windows registry. To fix clock keeps resetting problem you are required to fix registry error. You will need a good System Utilities program that includes a Registry Cleaning feature. Registry Cleaner deeply scans registry problems and fixes them instantly.
To download System Utilities program including a Registry Cleaner click here.
Scan System for Viruses
Attack by viruses or spywares on PC may also results in this problem. To fix this issue you have to completely scan your system for malicious or infected applications and clean all the files detected by antivirus program.
Download Clock Keeps Resetting Fix Tool
Posted on Jul 19, 2011
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: i bought my new Sony Vaio VPCEH last 2 weeks ago,. dual core, 2.3ghz, 4gb ram.. what i wondered is why my cpu almost overload all the time even i just use firefox, or explorer (opening folders ) or so
The CPU is runnimg with a useage of 45-60% as soon as the laptop has booted up because Kapersky is upgrading the virus definition file and is running a virus check on the files stored on the hard disk. When Kapersky has finished these tasks then you will see a drop in CPU useage.
NOTE as you install more programs and as your data files increase so will it take longer for Kapersky to carry out the virus scan.
Posted on Apr 19, 2012
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: sony vaio pcg 7184l system does not power on
That's why I always tell people;
1) Install the Battery
2) Connect the AC adapter (Charger)
3) THEN connect the AC adapter to power.
AC adapter disconnected, remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..1004, etc)
Let go of the Power On button.
Do this procedure 2 more times.
What we are doing here is clearing CMOS Error Codes, resetting BIOS setup back to the factory default settings; and resetting sensor values in the power circuit section of the motherboard.
Now reinstall the Battery. Reinstall the AC adapter. Plug back into power. WAIT 1 minute, turn the laptop on.
Still no?
Suggest we have a problem Houston.
Power MOSFET's in the power circuit section of the motherboard, or may be just a bad Power On switch, now.
The Sony VAIO PCG-7184L is also the VAIO VGN-NW235F
http://www.insidemylaptop.com/replace-lcd-screen-sony-vaio-nw235f-laptop/
http://www.youtube.com/watch?v=F3KQ6_SlJsw
Use an ESD wrist strap, and have it's alligator clip attached to a good ground source. Average cost is around $3 to $6.
One example.
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
I feel an Anti-Static Mat is unwarranted.
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
Look at the motherboard where the DC Power Jack is mounted.
(The DC Power Jack is where the AC adapter plugs into, on the laptop)
You'll see Power MOSFET's, and MLCC's surrounding them.
[Multi-Layer Ceramic Capacitor. They are also SMD/SMT, as the Power MOSFET's are.
Surface Mount Device/ Surface Mount Technology ]
This is an example using HP Pavilion dv6000 series, and Pavilion dv9000 series, of Notebook PC's,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Uses a Fairchild Semiconductor International - FDS6679 - Power MOSFET, and an Alpha & Omega Limited - AO4407 - Power MOSFET.
Looking at the second photo down with the AO4407 circled in Yellow;
Look at the rectangular smaller object to the immediate Right; that has the dark wide band across the middle of it.
This is an MLCC.
There is one above it, one above that one to the Top; one to the right of the top one; and one to the right of it.
See if any of these are burned/blistered also.
Or it might be worse, Clifton,
http://koti.kapsi.fi/jpa/stuff/pix/travelmate_6292/
May be time for motherboard replacement.
http://www.ebay.com/itm/Sony-Vaio-VGN-NW242F-PCG-7184L-A1747083A-3276432-Laptop-Motherboard-Tested-/281040027261?pt=Motherboards&hash=item416f4a7e7d
Not advertising for seller, nor website. Just presenting an example.
For additional questions please post in a Comment.
Regards,
joecoolvette
[More examples of procuring Power MOSFET's, MLCC's, and other related electronic components; plus procedures for de-soldering/soldering SMD/SMT components,
(Use a low wattage soldering iron (25 Watts?), Rosin core solder, rosin flux paste, and flux paste brush; instead of a Soldering Station.
Use Isopropyl Alcohol, and an old toothbrush to clean the motherboard, after removing components, to remove the residue left behind.
CAUTION!!
Isopropyl alcohol (Rubbing alcohol), is EXTREMELY FLAMMABLE.
Use in a WELL ventilated area with NO sparks or flames present )
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
Scroll down.
One dollar, one penny, USD
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
AO4407 is phased out. Using one of the cross-reference examples given,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
Scroll down.
78 Cents USD.
[ The 'legs' on the sides are J-leads ]
MLCC's that are SMD/SMT, and 4.7uf (MicroFarad) examples shown, at 16 Volts (DC),
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wrjcZ1z0x565
http://www.youtube.com/watch?v=5uiroWBkdFY
http://www.youtube.com/watch?v=b9FC9fAlfQE
Posted on Dec 19, 2012
Rohan Laszlo
  • 59 Answers
SOURCE: sony vaio VPCEH 3A FX (PCG-71912L) webcam not
your lcd cable is broke....need replace.the webcam's cable is whit the lcd cabe togheter.maybe in a certain position will work but if lcd moved, stops..similart problem had whit an acer 5000series..
Posted on Oct 28, 2013
How to make the led brighter
To fix the dim brightness level, remove the battery and pull the plug out of the mains power. Leave it disconnected for at least 5 minutes then plug it back into mains power. You should find the brightness has retuned to normal. I have 3 of these Clock Radios and the picture attached shows the comparison between dim and normal. For some unknown reason they intermittently decide to dim themselves. This may be why Sony included a dimmer in the next model up ICF-C318. Anyway I hope this helps
Jan 18, 2014 | Sony ICFC218 Clock Radio
Sony vaio VPCEH 3A FX (PCG-71912L) webcam not working. Drivers are OK - uninstalled and reinstalled. Green light next to the webcam comes on when Capture button pressed on Arcsoft webcom companion 4, but...
Oct 28, 2013 | Sony VAIO Computers & Internet
Clock wont keep time
Right click the time. a box should pop open ...go to " Adjust Date/Time".. when that opens up go to "Internet time" at the " Sever" make sure your clock is set to " time-a.nist.gov "..if not set it to that then click Update !
I hope that has helped you out ! :)
Jan 26, 2013 | Sony VAIO® VGNFE28H PC Notebook
I bought my new Sony Vaio VPCEH last 2 weeks ago,. dual core, 2.3ghz, 4gb ram.. what i wondered is why my cpu almost overload all the time even i just use firefox, or explorer (opening folders ) or so
Apr 18, 2012 | Sony Computers & Internet
Hi i am trying to find the output voltage of the mains transforma ? 120v in whats the output
Mains transformer output volts are 12V AC for Sony ICF-CDK50
Circuit location is T901 and part number is 143591722 .... TRANSFORMER, POWER (US, CND)
Hope these info will help you.
Thanks.
Nov 05, 2010 | Sony ICF-CDK50 Clock Radio
Clock Losing Its Memory
Our oven clock does the same thing every time the power blips, but we live way out in the boonies and expect occasional problems. Do your lights blink too? Check with your neighbors to see if they have power problems. If this is a chronic situation, contact your power company to see if they can repair the situation.
Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reair required on Sony Vaio
I have not heard of this problem with Sony Vaio's. Have you tried another powersupply? you might have a battery that doesn't charge or a faulty mains connector?
Aug 15, 2008 | Computers & Internet
CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
Mar 04, 2008 | Sony VAIO VGN-FS640W Notebook
Sony VAIO FX150K Notebook Logo
109 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
