How do I lower the feed dogs?
SOURCE: Feed dogs
There is a switch somewhere below and on the freearm....depending on the model, it may be front, rear
(or inside the front door if a front loading bobbin machine)
.........flick the switch left or right to raise/lower,
(up or down if front loader)
.......just remember the handwheel needs to rotate one full revolution to re-engage raised feeddogs after being dropped.
If you still have trouble, post back with details of the model......
NOTE: some lesser models do have a legacy moulding where the switch would be, but do not have the actual function.
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
SOURCE: Feed Dogs won't come back up!
Have you tried sewing with the machine after setting feed dogs to up position. You may already realise but it takes a full revolution of the machine to engage and raise the feed dogs after setting the feed lift control to up (the feed dods will drop as soon as you adjust the feed lift control but will not raise until a full revolution of the stitching mechanism).
If you have already tried this unsuccessfully try removing the cover below the feed dogs and spray lubricant on the feed linkages and try freeing them.
