Kenmore 17252 Free-standing Dishwasher Logo
A
Anonymous Posted on Dec 18, 2013
Dishwasher hose keeps coming off faucet - Kenmore 17252 Free-standing Dishwasher
2 Related Answers
Anonymous
  • 574 Answers
  • Posted on Jan 24, 2010
SOURCE: hose comes off of the faucet
A quick easy fix would be to get a hose clamp and tighten it down on the hose to keep it from popping off
awrench459
  • 7 Answers
  • Posted on Oct 31, 2014
i fixed mine with this part.it was maytag portable dishwasher.and didn't have to replace or buy a new hose.i sure hope it can fix yours.as I look for hours online.
285170 - Collar, Brand New Whirlpool - Maytag - Kitchenaid Factory Original Item.
Whirlpool gold drains all the time, unable to fill
Hello
Ensure the water faucet is turned on and the connection between the water and the dishwasher is secure. The hose connector should be snapped into place between the water faucet and the water hose.
Straighten the water hose and check for possible obstructions in the water hose, the water faucet and the hose connector. Clean as necessary. Turn on the faucet hot water slowly until it is all the way on to ensure proper water flow to the dishwasher.
Open and close the dishwasher door firmly. The dishwasher will not start a wash cycle if the door is ajar. Verify that the dishwasher is plugged in to a working power supply and that a wash cycle has been selected.
Avoid running other appliances that use water, such as a clothes washer, while the dishwasher is running, to avoid improper water pressure. This may result in a lack of water flow to the dishwasher.
Check to make sure large dishes, such as cookie sheets, pots or pans, are not blocking the spray jets. Avoid overloading the dishwasher.
Sep 28, 2011 • Dishwashers
I have excessive rocks/stones in all my faucets and I believe the supply line to my dishwasher...it's causing big problems I take off the faucet and rinse out rocks constantly, but they keep coming back. ...
You can remove the hose or pipe coming into your dishwasher and get the **** out there, usually there is a screen there...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
My dishwasher won't drain
There are probably two valves under your sink that control hot/cold water they maybe turned off. Or the hoses are kinked
2answers
Hose comes off of the faucet
2helpful
My portable dishwasher hose that attaches to the faucet is to short for where I want my portable dishwasher to sit. I would like for it to sit in one spot. I am not allowed to alter or cut holes in the...
You should be able to find extension or replacement hoses that you can use to extend the existing hoses at a hardware store. If you need to join two hoses that have female connectors, adaptors with two male connections are available.
Nov 09, 2009 • Dishwashers
1helpful
How to hook up detached dishwasher to faucet?
Hello there:
you are going to want to make sure that the threads on the hose match the faucet and also make sure that the gasket is in place you might even need to get a adapter for the unit to hook up to the faucet.
i would consult the manufacture or the users guide for further help
2answers
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Connector hose
the water pressure is too high in the intake for your kit. use a higher grade kit or reduce the pressure .
Faucet Attachment Leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
