White Westinghouse model #MWX413REW The washer wont go into the spin cycle, I smell a burning smell(the belt is in tact, but squeeks) I can't seem to find the problem. How many belts does this particular model have ..? To give a background to what made this occur..My nephew overloaded the washer with heavy jeans
SOURCE: washer make a grinding noise in the spin cycle; barrel does not spin in spin cycle
check the transmission out or it can be a clutch problem
SOURCE: washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
SOURCE: westinghouse heavy duty washer
Check this website out. It has a good questions and answers section. I would guess that it is the water inlet valve in the washer, but it could be a few different things.
http://www.repairclinic.com/0088_11_1.asp
I know of a different site that has good prices on parts. I have ordered from them numerous times. Let me know if you need that link.
SOURCE: White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
SOURCE: spin cycle not completely spinning out
Could be something stuck in the pump. Could be a bad belt.
This brand eats belts if the tub is overloaded even occasionally.
Remove the front panel and inspect the belt. Any glazing on the belt it should be replaced.
Remove and check the pump while you are there.
