no need cd drive, you can copy the drivers and save to tablet easily. but tablet installed android os, need to find android drivers, windows need windows drivers
Or,if you have the original Win 8 cd and product key,you can re-install Win 8 and during the process partition the hard disk. But doing this may result in losing all your data.
First download and install the correct software for the Printer on the laptop, you didn't post the HP printer model. In the install of the software follow the on-screen instructions. OR plug in the Printer using a USB printer cable, the Win 8 software should try to apply the driver, if available, but you may not have ALL the printer functions until you install the correct HP Printer software.
might due to harddisk partition and format.
you need to use other utility software to format then only install.
But your recovery parttition will gone.
Never able to restore back to win8
Plug your Bluetooth device into your computer's USB port. You will need your device in place when you install the software so that the hardware and software registry can form necessary links.
Step 2Insert the software CD into your computer's CD drive. If an installation window does not automatically pop up, go to the "My computer" section of your computer and click on the CD icon. You may need to look for a file called Setup.exe.
Step 3Follow the prompts to install the software. You will have to identify yourself and will probably have to type in a registry key from the box that the Bluetooth software came in. You will also have to select a folder on your computer to house the new program; the default is usually OK.
Step 4Wait for all the necessary components to finish installing. Once done, click the finish button and then restart your computer. Once your computer has been rebooted, launch the software and ensure that it is working properly with your Bluetooth device.
If the backup and recovery disk are for that model of computer , just remove VISTA or Reformat the hard driver using software outside of Window, then reinstall all the Xp stuff, just as if you had a new hard drive. Save all personal files first, of course..
