Magellan Roadmate 760 GPS Receiver Logo
A
Anonymous Posted on Dec 18, 2013
My magellan 2120T when powers up the clock just keeps going around. and won't power up
2 Related Answers
Anonymous
  • 5 Answers
  • Posted on May 16, 2010
SOURCE: My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
Anonymous
  • Posted on Mar 17, 2013
SOURCE: magellan roadmate 2120T too slow after updates
Magellan support was actually pretty good helping me with the exact same issue. The problem (at least in my case) was that the map files were fragmented. I tried using the Windows defragmenter, but that made fragmentation even worse! The Magellan support engineer recommended I download UltraDefrag instead:
http://ultradefrag.sourceforge.net/en/index.html
Here's what I had to do to completely resolve my issue:
1. Download and install UltraDefrag
2. Connect my GPS to my PC
3. Move the MAP directory from my GPS drive (J:) to my hard disk
4. In UltraDefrag, make sure Action > Skip removable media is not selected
5. Run the optimizer (Ctrl-F7 or Action > Full optimization) after selecting the GPS drive (J: on my computer)
6. Copy the MAP files back to the J: drive AFTER optimization has completed
I double-checked the fragmentation after the files were copied and got 0%. After disconnecting the GPS from the PC, the unit rebooted and doing an address search no longer takes 15 seconds. POI searchs are also much faster than before.
Change time that is on my gps
  1. Open the Main menu and tap Settings.
  2. In the Settings menu, tap Set clock.
  3. Select how the time should be displayed, then tap Next. ...
  4. Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS
How to get a replacement power cord for my Magellan 3045lm that will plug into my truck?
Another way to reach Magellan is through chat. Go to http://www.magellangps.com/support . Click on the chat link icon. You should be able to chat with an agent within a couple of minutes. You can also order online Product Number: AN0207SWXXX
Content manager does not find software update the magellan's site says is needed?
Contact Magellan tech support to see if there is a compatible software you can use for your GPS.
Loading a philippines map
Visit the website of Magellan for your country or their global site. Find the maps, pay for them and download to your computer. You will have access to the installation instructions. Usually you install some software by Magellan, you connect your device to your computer and the proprietary software will install them on the GPS.
2answers
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 • GPS
4helpful
2answers
Magellan roadmate 2120T too slow after updates
My boyfriend has this gps and it froze up on him around the time that the clocks went back what can I do
Try sending it back to Magellan or go to Magellans Website www.magellan.com and download their updates. You will first need to download Magellans software - then hook your gps to the pc with the usb cord.
One other thing - try a wall charger for 48 hours. I have seen this work.
4helpful
2answers
Downloaded map update to Magellan 760 - now the unit will not even power on. What can I do? Carolyn
charge it up for a few hours then press and hold the power button till it powers up
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
