Question about R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop
IX PACIUP4240 15'' LCD, No POST or boot
I was given a PACCO Group IX PACIUP4240-L 15'' LCD computer that was escribed as "inoperative". Came with XP Home, 256 MB DDR memory and 80GB HD and zero documentation. Upon switching on the first couple of times I would get the black and white screen saying Windows did not start successfully last time, what did I want to do? I tried "normal start", "safe mode", "last known good configuration". None of these would produce a boot. Then, and ever sense all I get is a brief error message stating "CABLE NO INSERT" in a blue box center screen, then blackness. No beeps, no other sounds (such as the 3 1/2" drive cycling as it did initially.)Thinking it might be cable connection problem from long-time disuse, I opened the case, and removed/burnished all visible cable/plug sets. While at it I added 256 MB memory and replaced the broken CPU socket plastic base that mates with the heat sink down pressure spring. Upon restart I still get only the CABLE NO INSERT message, and no "power on" LED (to left of power button) or HD activity LED (to right of power button) although both did light during the first few boot attempts. I realize this beast is really only good for a doorstop but I have a menial task I would like to use a dedicated computer for and the form factor is ideal for it. Suggestions? TIA
[email protected]
Posted by RedDawg on
  • RedDawg Oct 16, 2007
    P.S. I can't even get into the BIOS/setup screen to try changing the first boot device to the floppy drive. With no docs I don't know what key(s) to push but have tried escape, delete, all F keys, etc. ?? -RD
    Well, after much of nothing, I found putting the CMOS jumper back in the 1-2 position extremely helpful. From there, nothing much changed except on pressing the start button there was a brief light "halo" flash around the outside border of the screen and I believe I could hear the HDD spinning up where I had not noticed it before (but still no HDD activity LED.) Did not enter set-up automatically, same "CABLE NO INSERT' error message, could not enter set-up using F10 or any other key(s). Next?
Anonymous
The error message "CABLE NO INSERT" refers to the lack of video signal to the LCD. To fix it you have to use a short VGA cable that connects VGA output of motherboard to VGA input of LCD. Only then you are going to see video output on LCD screen. Your other option is to connect external monitor to VGA output on motherboard. Either way you are going to see motherboard's video.
Posted on Dec 19, 2007
Anonymous
    Problem Solver:
  • 9 Answers
Just open your system and see the CMOS clear jumper just beside the HDD port there should be three pin just change the jumper If jumper is seted into 1-2 then you put it 2-3 now system start by default  It will go into CMOS then go to advance setup set the boot prority as first boot device HDD0 and pree F10 to save it
then see & post again
Posted on Oct 16, 2007
What is the maximum memory capacity for the MX6027 model ?
Hello Marc,
The maximum is 1 GB. Standard, it comes installed with 256 MB but you upgrade with additional 256 MB or 512 MB memory modules. The modules you are looking for are:
256 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
512 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
There are lots of places on the web to find decent prices for this memory. I have included a few below.
http://www.memorystock.com/memory/GatewayMX6027.html
http://www.pcmemorystore.com/Gateway-M_Series_Notebooks-MX6027-ram.htm
http://www.computermemoryoutlet.com/Gateway-M_Series_Notebooks-MX6030-memory.htm
This document includes instructions for replacing the memory. It's a simple straightforward process.
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Hope this helps.
Have a blessed day.
Thanks for using FixYa
Jul 29, 2011 | Gateway MX6027 Notebook
I recently received and old Systemax Tiger computer. It has Windows XP on it and has 256 MB of DDR SDRAM on it. Now, i also have an old Dell computer that has 512 MB of SDRAM in it. Will my Systemax...
No, you will have to use DDR memory only. Fortuately, DDR id VERY inexpensive now.
I can recommend www.TigerDirect.com
They are a very low priced but reputable company. This is a current item, with price.
Corsair Value Select 512MB PC2700 DDR 333MHz Memory $17.99ea
Good luck
May 27, 2011 | Computers & Internet
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Pacco group ix my ciu p4 2.66ghz 15" tft
hello i got the same problem like u,but the thing is i call some1 2 check my p.c and he took my power supply and never give back 2 me,can u let me know that serial # or any info about the power supply....thanks or if u bought 1 4 u...........
Jul 10, 2008 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop Logo
394 people viewed this question
Top R.A.M. Computers Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a R.A.M. Computers Computer and Internet Expert? Answer questions, earn points and help others
