Question about GE JVM1651 Microwave Oven
Light bulb replacement
The light bulb needs to be replaced for the light on GE microwave model # jvm1650.  The bulb came out but separated from the base of the bulb.  Could you please tell me how the base can be removed?  Does it screw out, pop out, or anything of that nature.  So far I haven't had much luck getting it out.
  • Anonymous Mar 31, 2008
    had the same problem--bulbs broke out of base, could not get them out. sprayed with WD40, and used needle nose pliers to work them loose--be careful, I chipped the plastic housing being a little too vigorous. If you have to, let it sit for a bit, so the WD40 can work. As always, disconnect the power first!!!!!!!!!
I had the same problem--tried to twist bulds out, and they separatd from the base. I sprayed both sockets with WD40, and worked them loose with needle nose pliers. be careful- I chipped the plastic housing working a little too vigorously. Let them sit a bit, so the WD40 can work. BE Sure to shut power off first!!!!
Posted on Mar 31, 2008
  • GE Master
  • 9,179 Answers
Of course, do unplug the oven first.
Another neat old trick is to lightly spray (or drip) the area between the broken bulb and the socket with WD40 or another lubricant then stick a carrot or potato chunk into the broken part and unscrew it.
But then you need to be sure the socket is dry. You can do that by wiping it off with high-grade alcohol or blasting it with air.
Then put the new bulbs in BEFORE you reapply power.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 473 Answers
Yes it just unscrews.  Unplug the microwave first!  Then use some needle nose pliers and put them inside the base open the pliers to put pressure on each side of the base.  Now turn the base counterclockwise.  Let me know how it turns out.
Posted on Oct 18, 2007
6ya staff
SOURCE:
JVM1340 lights not working
Behind the top grill above the door is an access panel to change the light bulb. If the bulb is good but light still don't work, its possible the door switch is bad, but normally if the switch is bad the turn table won't work either. Most likely just a bad bulb part number you would seek is WB36X10003 this is not cheap for a bulb, you maybe able to get a replacement from a local lighting center near you. its a 40 watt, 130V bulb
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 03, 2013 | GE JVM1650 1000 Watts Microwave Oven
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
I need to replace the bulbs in this microwave oven. Do you know where to find replacement bulbs?
If they are meant to be user replaceable, you can download the owner's manual here.
If not, you will have to disassemble the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number
here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 17, 2011 | GE JVM1650 1000 Watts Microwave Oven
How to replace door frame on GE microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge microwave jvm1650
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.
Nov 16, 2008 | GE JVM1650 1000 Watts Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
Removing and replacing door assembly
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 08, 2007 | GE JVM1650 1000 Watts Microwave Oven
Surface Lights Don't Work
We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1651 Microwave Oven Logo
133 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
