I can not advance powerpoint slides using the remote.
Find links to information about saving presentations in the See Also section.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
The Broadcast Slide Show dialog box opens.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
PowerPoint creates a unique URL for your slide show.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
