if you have an iPhone you should not be putting a memory card into it. It has built in memory so you would not need to put another one inside it. If this is for another phone. trying erasing everything on the memory card and trying again. Good luck!
Take the card out and review the pictures. Put the card back in and review again. Are the pictures different? Most cameras continue to use the internal memory until the pictures on it are erased by formatting in the camera with no memory card inserted. Then, when the card is inserted, the camera writes to the card.
Remove the memory card from the camera if it isn't already, and look
along the left edge of the card. Find a small tab and slide it forward
(to the unlock position) and carefully slip the card back into the
camera and try again. If it reports locked again, carefully remove the
card to see if the tab has moved back to the locked position.
If
the tab is moving to the locked position during the insertion process,
you could place a small amount of tape along the card edge - over the
tab - and carefully insert the card again. You might have to remove
some tape to allow the card to fit into to slot. If you never lock the
card - you could put a very small drop of super glue on the tab to hold
it in place. Wait for the glue to set completely before inserting into
the camera.
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
