Bosch 23 in. SHU 8805 Built-in Dishwasher Logo
A
Anonymous Posted on Dec 18, 2013
Flashing light in a finlux c13 dishwasher - Bosch 23 in. SHU 8805 Built-in Dishwasher
2answers
Finlux. Just as wash cycle begins, why do 3 & 4 blink and it stops?
sorry that make is not here so suggest you call a local dealer
Jan 25, 2021 • Dishwashers
My FINLUX C13 reset button keeps flashing and cycle stops wat could be wrong and can I fix it myself, thank u
Dishwasher lights flashing or blinking. The heating element heats up the water to operating temperature. If the water doesn't reach the proper temperature after a set amount of time, a light on the control panel might start flashing. ... If the drain pump is not working, a light on the control panel might start flashing.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/28---/Dishwasher-Lights-Flashing-Or-Blinking
https://www.youtube.com/watch?v=5-aH_tVbYi8
Apr 17, 2020 • Dishwashers
Finlux tv won’t turn on standby light keeps flashing
https://www.sony-asia.com/electronics/support/articles/00011057
I did see another suggestion when you unplug the tv hold the start button 30 seconds while tv is unplugged.
Finlux c13 dishwasher starts then stops with flashing red light
Wonder if any one can help. These two red lights flashing. Nothing happening sounds like its tring to intake water but not happening .
Mar 04, 2017 • Dishwashers
Finlux tv showing black screen after switching on by remote. standby light is flashing buy mo picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Finlux c13 dishwasher no lights coming on and won't work I have changed the fuse in the plug and no diffidence still nothing happening does anybody know what it might be Thank you
If it's hard-wired into the house wiring, turn off the breaker that controls it for 2-3 minutes, then flip back on. It might recycle and power up. If plugged into a wall socket, unplug it for 2-3 minutes, then plug back in. OR there may be a reset button somewhere on the unit. Consult your manual.
May 23, 2016 • Dishwashers
Tv does not come up standby light keeps blinking
It seems there is no information in the manual here http://www.finluxdirect.com/content/ebiz/shop/resources/pdf/46S8030-T.pdf
So you may want to attempt to talk to their support. They have free on line chat here Finlux Direct Help Centre
Good Luck
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
