Cant print excel,cant see on printer and faxes, cant make a default
Open Registry editor by typing REGEDIT in the RUN Prompt
Traverse to
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows
Right Click the Windows key and click Permissions...
Select Allow on Full Control permission and click OK
Close the Registry Editor and restart the machine.
Print after refiling canon image class mf4412 is very light
solution:-
change Doctor baled chack the print
SOURCE: Canon MF8180C "In Use/Memory" won't clear
http://support-au.canon.com.au/contents/AU/EN/8000123601.html
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine:
Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine)
Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part).
Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.
Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
SOURCE: Canon MP210 with Mac OS X 10.4.11 problems with printing docs
Hi
I have OS-X 10.4.11 and had the same issue; any printing just spat out blank pages.
I installed the following driver which completely resolved the issue:
http://software.canon-europe.com/software/0029270.asp?model=
There's a similar one for 10.5 that I haven't tested, to be found here:
http://software.canon-europe.com/software/0028432.asp?model=
If you use 10.5 and this driver works for you, please let others know by posting here, too.
Good Luck
Draqul
SOURCE: Canon MP620 Wireless All-In-One can't print to it
Hi
I had exactly the same problem. Here is how I solved it.
I deleted all the previously installed items (although this might not actually be necessary). Then I re-installed using the 'Easy Instal' option from the CD.
The CRUCIAL part is this: - after you have tested your connection to the printer - and it is all fine - another box should appear with a MAC address for the Scan Twain. Highlight the string of numbers and click APPLY.
THEN THE MOST IMPORTANT BIT - look at page 54 in the set-up guide. And follow the instructions which are:
When the printer utility opens click ADD - then go to 'more printers' select the MP620 with the string of numbers after it. This is the one you want NOT the one that appears automatically when you complete the installation.
make this printer your default and away you go! That should work as it has for me and i have been pulling my hair out on this for about 3 weeks!
SOURCE: I have and Canon iR3570 and when SNMP is disabled
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
