6 years old, getting power to the outlet and at the rear pan where the dryer cord connects. Start switch will read ohms and go to zero when engaged
SOURCE: Dryer model DBXR463. Power is
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Check
to see whether there's power getting to the dryer. Is it plugged in? If
you plug something else into the outlet, does it work? If not, check
for a blown fuse or tripped circuit breaker.
Door switch
If
the door switch or the door-switch actuator is defective, the dryer
won't work and you need to replace the failed component. The switch is
inside the dryer main housing near the door frame. Sometimes you need
to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse
that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an
inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your
dryer either just stops heating, or it doesn't work at all. Be sure to
inspect the venting/heating system before replacing the fuse to put the
dryer back into operation. (You can't re-set this type of fuse.)
Wiring
Often
the main wiring connection from the house, at the dryer, burns and the
connection breaks. In this has happened to your dryer, you need to
replace the power cord and the terminal block inside the dryer to which
the wire is attached.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
SOURCE: Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
SOURCE: power cord on my dryer to short to reach installed
Never ever use an extension cord with any major appliance. You can however, purchase a longer cord (exact same, just longer) at your local hardware store and install it directly to the machine. Anyone who can install a ceiling fan could do this for you. It's pretty simple. You could also remove the one that is on the machine and bring it with you to make sure you get the exact same wire (just longer). :-)
Hope this info was helpful to you. Good luck!
Testimonial: "Simple is best. Merci"
SOURCE: The dryer stopped working in the middle of drying
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
