Question about Konica Minolta bizhub C250 All-In-One Laser Printer
No print on copy in bizhub konica 280c copier
If i make a copy it very very light yellow printing on the paper
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Replace the yellow image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 09, 2016
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Posted on May 11, 2008
Anonymous
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
taminol
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
Anonymous
  • 24 Answers
SOURCE: Cannot print from PCs to Konica Bizhub 350
AS IS ALWAYS THE CASE CHECK THAT YOU HAVE LIGHTS ON THE NETWORK PORT OF THE COPIER, IF THIS IS ALL OKAY THEN DOWNLOAD THE LATEST DRIVER AND LOAD IT TO SEE IF IT CURES THE ISSUE. IF YOU KNOW COMPUTERS WELL THEN PING THE MACHINE FROM THE CMD PROMPT FIRST.
Posted on Jun 25, 2009
Bizhubman
Ben
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
Printing copies crooked
prints ok from a different tray????????????????????
Feb 14, 2014 | Konica Minolta Bizhub C224 Color Copier /...
I have a bizhub 300C. When I print a pdf the top inch is faded
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Very very light only yellow printing on paper in konica 280c bizhub machine
replace the image unit yellow touch the oil can what does it say??
Dec 17, 2013 | Konica Minolta Bizhub C280 Color Copier
Yellow background after the first print or copy bizhub c351, how can I run image Quality adjusment
The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
Feb 01, 2013 | Konica Minolta bizhub C351 All-In-One...
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
May 20, 2010 | Konica Minolta Bizhub c203 Copier
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub 920
You need to set machine for extra cassette.
Nov 23, 2008 | Konica Minolta Di1610 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
42 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
