SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
SOURCE: honeywell kaz HZ-705 oil filled heater
i have the same problem. i do'nt know if i have to refill the oil; if so, what kind of oil?
Matt
please e-mail me = [email protected]
SOURCE: Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
SOURCE: Instruction manual for hz705 honeywell oil heater
May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
SOURCE: Honeywell HZ-709 oil filled radiator heater-all
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
