Question about Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV
My sony wega 51" rear proyection no turn on
Hi, I have a sony wega kdp51ws655, the issue is that the tv was 10 month with out use and not conected at the electrical oulet. this week I tried to turn on, but just the red light blink 9 time. please help me to resolve this problem. thank
  • LeShunda Nov 23, 2007
    The standby LED consistently blinks when tv is plugged in. Their is no sound or audio.
  • dnlpkr Jul 01, 2008
    I have the same problem, my 3 year old "$1,200 to boot" big screen TV blinks the standby light 9 freakin times and doesn't turn on of course. I can solder a diode or two on a board if I only had the C&D for the thing that Sony and every repair center on the globe acts like is a "NATIONAL SECRET". Capitalism at it's finest I guess, huh? Can anyone help? My E-mail adress is [email protected]
Hello had the same prob need to replace DIODES, D6116 and D6301 very cheap to buy on line and then they need to be sotteried on (sp) .
Posted on Oct 31, 2007
6ya staff
SOURCE:
Sony wega 51" standby light is blinking 5 times repeatedly. what is this code for?
The picture tube is getting close to failure. Has the picture tube been replaced before? If it hasn't it is probably about due the Vegas were great long lasting T.V. sets but after about 15 years need a new picture tube.
Jan 15, 2013 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
It will turn on somedays and work great other days nothing red light blinks 10 times
Thats a HV issue which is indicating that there is most likely an issue with the any of the following items all located on the D board. They are:
Transistors Q8013 & Q8014
Resistor R8051
Integrated Circuit IC8005
Aug 31, 2011 | Sony Grand WEGA KDP-51WS655 51" Rear...
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Purchased Sony Grand Wega in 2007 I believe. Replaced bulb about a year ago but now the picture has a green tone to it. What do I do?
I hope our experts have been provided you helpful info in chat session about tv problem yet you can let me know if further help is needed as being Sony tv tech I can help you more.
Thanks.
Sep 21, 2010 | Sony Grand WEGA KDP-51WS550 51" Rear...
My kds-r60xbr1 sony wega projection tv is blinking green then red and wont go on how do i fix this problem .i also just replaced the bulb about 3 months ago.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My Sony Grand WEGA LCD rear projection 51" turns itself OFF every 20 sek and turns itself back ON after every 35 sek. ???
Try resetting the TV to the factory settings. Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Televison & Video
I haqve a sony KDP51ws655. It won't come on , the standby light blinks 10 times
Please check and replace the D6301 & D6109 in D BOARD with the same value.
Thanks
Nov 24, 2009 | Sony KP-61V90 61" Rear Projection...
My SONY HD projection TV KDP-51WS550 (2005) suddenly lost the picture and the Stand By /Timer light starting flashing 5x and then repeating. The next morning the TV came on and the flashing stopped. Turned...
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
Jun 15, 2009 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV Logo
525 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
