Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Check system=pal.ntsc
Press menu
Highlight picture settings
Change picture mode to movie or other mode by doing that you will be able to adjust all the pictures al well, play with the color temp, brightness, contrast, tint color backlight sharpness, you have to find the right settings. play with the white and black balance shades red, green, blue like offset and blue, red green gain.
