Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player Logo
Question about Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player
CAN'T GET MY iQ SOUND SC-6D MINI KEY CHAIN DIGITAL PHOTO VIEWER TO WORK
I plug in my iQ sound SC-6D photo viewer in and it does nothing, i inserted disc into my pc and it only comes up view files. no download, no installation or anything. It's a brand new one right out of the package.
3 Related Answers
Anonymous
SOURCE: my iq sound mp3 (IQ950FM) won't download music files.
Make sure they are in MP3 format. If they are, you may need to reset the MP4 player to the factory setting by navigating to: Settings -> Default Set -> OK
Posted on Mar 01, 2009
Anonymous
  • 4 Answers
SOURCE: BROKEN
Good luck finding one. You bought the product hook line and sinker like the rest of us that did the same ebay transaction, now we are stuck with a pile o' **** that has a bundle of headaches installed. Freezing up , file errors, scripture writings on your files, unreadable files whatever can happen to this will happen. Best thing for you to do is chalk it up as a loss, save your money and buy something with a dependable brand name or one that has a service number available before you buy it....just sayin.
Posted on Mar 17, 2009
Anonymous
SOURCE: can not turn on
Mine quit working after only 1 day! Common problem for these chinese junk mp4 players. I'm still looking for a fix.
Posted on Dec 16, 2009
How much time should a iQ sound mp3 player charge
MY IQ SOUND MP3 ONLY STAYS CHARGED FOR 5MINS,I PLUG IT IN TO CHARGE AND INSTANTLY IT SAY BATTERY FULL BUT ONLY LAST AGAIN 5MINS,ANY IDEAS.
4answers
Digital photo album - keychain
The message "No Photo Viewer Found, program termined" will happen unless you have the keychain plugged into the USB port in syncronization mode not charging mode. It's just saying it can't find a Photo Viewer plugged in to sync with. That should solve your problems. You can't update you image library unless it is plugged in
Regards
Balisonu79
1helpful
Can not turn on
Mini SD card
insert the mini sd card when the player is swiched off then turn on the player and try
Mp4 mini touch screen 8gb
there is a tiny hole on the side stick a pin in it to reset it
2helpful
How to upgrade the mini mp4 touch screen
you go to itunes.com and find the update tab, plug in the mp4 and hit save or run and your set ******* ******** mother *******, damb niggros
TRYING TO OPEN PHOTO VIEWER, WON'T OPEN
I have my key chain completly charged and the software downloaded and when I plug into the computer it says updating like ie is supposed to but then I can't into my pictures to download them onto the key chain
14helpful
3answers
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
5helpful
5answers
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Top Digital Mind Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
