Question about JUMP START SYSTEM
Looking for husky 12 volt adapter for model #HSK012HD
1 Related Answer
SOURCE: can this product be repaired?
if its just the clamp then yes take off an replace clamp 9MAKING SURE CLAMP IS TIIGHT AN SECURE0
Posted on Jul 12, 2012
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Can this product be repaired?
Jul 12, 2012 | JUMP START SYSTEM
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
My tv Adapter is not working and i need another one . this what is at back of the ADAPTER AC ADAPTER SN 0530+___O___- MODEL ;AD0603S110/220-12 INPUT:100-240V~1.5A. 50-60HZ .OUTPUT:12VDC= 5A THAT...
The important information is the output voltage (12 volts DC) and current (5 amps). You need an adapter with those ratings and a plug with the proper size and polarity to fit the TV. If necessary, you can salvage the output cord from the bad adapter and splice it onto a replacement if you can't find one with the right plug. You need to be careful to get the polarity right or you can damage the TV. Most sets have the center pin positive, but you want to check to be sure. The set usually is marked with the information, and it may also be on the old adapter.
You may be able to find an exact replacement adapter by searching for your specific TV brand and model number and "replacement power adapter". Many adapters are available through eBay sellers. Otherwise just look for a 12-volt 5-amp adapter and change the output cord as described if necessary.
Good luck and thanks for using Fixya!
May 16, 2011 | Goodmans 289NS 14" TV
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
I need a replacement 12 volt charger for an old Venturer car dvd player model fy035002.Can,t source it locally so looking for any ideas .........
try Radio Shack - look for a universal adapter - most of these adapters have multiple voltages including 12 volts
Dec 08, 2009 | Venturer PVS177W Portable DVD Player
Electrics not working
First check the dynamo outlet for current for that take one electric holder with D.C bulb(12 volt) in it and check whether the dynamo is generating the current or not.If it is O.K then check every cable subsequently using electric holder and
bulb(12 volt).
and if the dynamo is not working them you need to change the coils of the dynamo.
Jul 01, 2009 | 1999 Sym Husky 125
Low voltage on voltage inverter board
Probley got a week capacitor in the 12 volt supply, but without even a make or model number your guess is as good as mine
May 15, 2008 | Televison & Video
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
JUMP START SYSTEM Logo
85 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Sheldon Dedek
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
