Question about Nokia N70 Cellular Phone
N70 dont run
When the phone is turned on it displays  the word  (nokia) and don't go it stopped on nokia  word.
but when i plug charger when it is off  it charge and runs normally after turning on
    Sergeant:
  • 452 Answers
There is some problem with ur battery , change ur battery and try startup ur phone, i would also suggest u to try startup ur phone without the mmc just to cheak if its a virus problem...
Posted on Oct 20, 2007
  • 490 Answers
I would appreciate if u do restoring of handset after creating back up of all data....and ur handset display module chip may b damaged......
6ya staff
SOURCE:
How unlock nokia n70
A Nokia N70 can be unlocked safer and easier using unlock code. An unlock code for a Nokia N70 can be acquired from http://www.unlocking4u.com/nokia-n70/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia N70,
1 - Switch on your Nokia N70 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N70.
3 - Compose #pw+CODE+1#.
4 - The Nokia N70 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N70 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 21, 2012 | Nokia Unlock N70 N71 N72 N90 6630 6680...
When i charge my N70. the screen displays "Not Charging".. what should i do?
HI, IT COULD BE THAT THE CHARGER YOU ARE USING IS NOT COMPACTIBLE WITH THE PHONE, TRY USE THE CHARGER THAT CAME WITH THE PHONE.
Jun 01, 2010 | Nokia N70 Cellular Phone
Nokia n70 charger will not enterphone pin
Hi
Be sure that you are plugging in the right charger because some Nokia chargers are not compatible with the N70..
Also be sure that you are plugging the charger into the right port,The charging port of the N70 is the smallest hole under the phone.
Cheers
Mar 28, 2010 | Nokia N70 Cellular Phone
Pls somebody help me..my n70 cant charge battery.whats the possible reasons and solutions.?.pls help..
One. The battery is dead. check and change. two. The charger is bust. check and change. If the phone runs on the charger plugged in then charger is fine. three. both one and two. check and change. four. If dropped or thrown around however softly, the charging circuit broken. go to Nokia Care.
Jul 27, 2009 | Nokia Cell Phones
N70 not charging
Here is a generic solution for all mobilephones!
This problem could be caused by either battery, charger or firmware failure. you can try the following to secure which!
-Try your mobilephone with another charger or connect it to a PC using a USB cable
> if ok? the problem is your charger!
-Try your mobilephone with another battery
> if ok? the problem is your the battery!
-Try your battery and charger on another phone
> if ok? the problem is your mobilephone/firmware :(
If you dont have access to other phone, battery, charger or USB-cable you can at least try the steps below:
1. Turn off your mobilephone
2. Take out your battery, Sim-card and memmory-card
3. Connect your charger
4. Put the battery in
5. Turn on the phone
If it doesn't help, with a little luck! you should get a USB-cable, back yor phone up and reset it to factory default and upgrade your firmware/software on the phone to the latest version!
OBS! You should only do it with a fully charged battery! or you could damage your phone irreversibly!!!
Jul 12, 2009 | Nokia N70 Cellular Phone
No display
it is a display problem, just visit a nokia service centre and get a check up of it, and u will have ur running phone
Jun 02, 2009 | Nokia N70 Cellular Phone
Nokia n70
Don't try anything. Take phone to someone who has toolbox to flash it. Just write latest firmware version in it it will work 100%
Aug 17, 2008 | Nokia N70 Cellular Phone
N70 refuses to turn on nor charge
Hi
You can reformat your unit.. just follow this instructions. just off the fone then, press together the key no. 3 Astiris and phone in.. press in sustained position then turn on the power switch then you can see your fone is starting to reformat...
your unit has a virus...
Jan 06, 2008 | Nokia N70 Cellular Phone
N70 comes on with whie screen and hangs
a lot tobe done in that problem of your... but i can give you one of the best... place yur unit in table so you can be cmfortable...the press all the keys in same time these keys are key *,key3,the call,and power on switch... much better if you had buddy beside you..to hold the unit... press them in same time or together, dont release it until you dont see a word formatting... wait until it finsih and the unit will be restarted by itself... enjoy
Nov 14, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
