Question about Konica Minolta Bizhub Press C6000 Copier
Please set replenish toner unit correctly - Konica Minolta Bizhub Press C6000 Copier
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Install OEM toner not third party
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 09, 2016
How to solve error code c2552 in konica minolta bizhub c221
Abnormally high toner density detected cyan TCR sensor
• TC ratio in the developing unit which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively...
1 Reinstall developing unit.
2 Reinstall toner cartridge.
3 Check the connector between developing unit-FREYB CN4, CN6, CN8, CN10 for proper connection and correct as necessary.
4 Check the connector between FREYB CN1, CN2-PRCB CN4, CN5 for proper connection and correct as necessary. 5 Change developing unit.
6 Change FREYB.
7 PRCB ICP12 conduction check.
8 Change PRCB.
Aug 08, 2018 | Konica Minolta Office Equipment & Supplies
Sharp copier Mx 5000N is doing continuous toner replenishment I changed toner cartridge drum developer still replenishment what do I do
If the machine is still trying to add toner after the toner cartridge has been replaced & the developer is new then I would look at the toner supply motor for that particular colour. Also check for a blockage within the small tube between the toner cartridge & the developer unit. You could try swapping the toner supply motor with one of the other colour motors as they are all identical. If the fault switches to another colour then the motor is at fault.
You can also check the operation of the toner motor in simulation 10.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Office Equipment & Supplies
Bizhub c224e error code 2558
Konica-Minolta bizhub C224e Code: C2558
Description
Abnormally high toner density detected black TCR sensor
The TC ratio of the toner determined by the toner replenishment control is detected to be the predetermined value or over for consecutive times.
Remedy
1 Reinstall developing unit. 2 Reinstall toner cartridge. 3 Check the connector between developing unit-FRB CN13, CN14, CN15, CN16, CN10 for proper connection and correct as necessary. 4 Check the connector between FRB CN1, CN3-PRCB CN7, CN9 for proper connection and correct as necessary. 5 Replace the developing unit. 6 Replace FRB. 7 Replace PRCB.
http://www.printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20C224e&code=C2558
Aug 22, 2016 | Konica Minolta bizhub Office Equipment &...
Please set replenish toner unit correcty
Replenish toner unit is the unit that is secured with two screws and comes to the right and these are unscrewed. The presence of this unit is signaled by a sensor positioned under the top cover. Check that sensor for proper functionality in Service Mode.
Jun 01, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica - please set replenish toner unit correctly
reinstall the toner bottle correctly
Dec 15, 2013 | Konica Minolta Bizhub Press C6000 Copier
the whole section that houses the toner is not closed properly
Nov 12, 2013 | Konica Minolta Bizhub Press C6000 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Jan 21, 2011 | Kyocera FS-2000D Laser Printer
"TONER REPLENISHMENT IN PROGRESS
please remove the waste toner stored in the waste toner content box
Jan 11, 2011 | Sharp AR-275 Copier
C2557 error message
If is a BW 350 go to service mode ( stop 0 0 stop 01) counter apecial part counter reset drum and dev switc off the very quiqly service mode function run f8. Did you replaced drum and developer?
Aug 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub Press C6000 Copier Logo
104 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
