Question about Razor E100 Electric Scooter
Batterys showing full charge but when my daughter gets on in power kicks in then stops
Posted by Jason Sykes on
Janet Flynn
    New Friend:
Razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Posted on Dec 18, 2013
How do I get a full charge in makita 18 v batteries
these batterys and chargers are designed to accept a full charge and the green light comes on when charging is complete. If you are not getting adequate power from the battery it could need replacing or possibly something wrong with the tool causing a battery to drain faster.
Jan 08, 2012 | Makita Drills
I have minolta DiMage camera and it will not reconize fully charged batteries, it show battery as being 1/2 full and I put new batteries and it still won't reconize. I have cleaned the battery posts, but...
When you said new batteries, did you mean a fully charged battery? If so, it could be that your batteries are nat capable of holding a full charge. Otherwise, my suggestion would be to Call the manufacturer for tips or help.
Apr 10, 2008 | Cameras
Tip
Cell phone batterys
when you get a new phone always turn it on and let it run out of battery power then plug in the charger and let it charge the battery until it is full before you unplug it, that is the best way to get best battery life out of the battery, as with most batterys
on Dec 17, 2009 | Cell Phones
Pride Sundancer. Batteries will not charge. both batteries test about 50% charge. When I plug charger in to 110v, the needle on rear of unit barely moves. When I turn on key, charge indicator on on dash...
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Jan 16, 2011 | Pride Sundancer 3 Wheel Mid-Size Scooter
J.hughesneed to know when battery is full shows a white battery is that the color when full or is it still not charged
batterys usually show half colour when not full.
watch the battery indicator from time to time with mains power disconnected to see change
usually when charging the the indictor will flash.
run mouse over indictor if on screen and it should tell you how much % of battery is still left.
not possible to be more specific without model number
I hope this was useful.
Jan 11, 2011 | Computers & Internet
FULL BATTERY CHARGE NO POWER IN CAR
all though your battery showes full charge you may have a dead cell replace the battery and take old one to a chevy dealer and get your mony back bring your recept I like sears die hard batterys best only one mans oppion good luck CJ ps I had the same problem with my vett 2008
May 12, 2010 | 2009 Chevrolet Corvette
I can charge my acer for days and the battery will die within min
The Battery is bad and so its not retaining charge, You may need to get a new battery and from an authorised reseller.
Dec 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Batterys not reaching full charge
You can try this it might take a while but it should work , use the drill untill it actually stops, use it really hard , then recharge for the full time then use the drill again untill it stops [drain the battery ] even get the kids to hold the trigger untill it stops then recharge again eventually you will remove the memory block off the battery , works for me everytime smirf617
Jun 06, 2009 | Hitachi Tools KC18DCL 18V Lithium-ion...
I have a quatum 610 power chair when i use it the batterys (new) discharge fast i get about 2 miles per charge it makes a clicking noise but not all the time and even makes the clicking noise after its...
It is not shutting off. You need to bring it to an expert for service. Your problem sounds like it is electronic, not mechanical.
To stop it from discharging you can disconnect the batteries. The batteries should be hooked up in series 24vdc not parallel 12vdc.
May 16, 2009 | Pride Mobility Products New Pride Mobility...
My mp3
While connected to the computer, it uses the computer's power & the battery meter shows full. You need a new battery.
Jan 08, 2008 | SanDisk Sansa m240 MP3 Player
Razor E100 Electric Scooter Logo
483 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
