Ranging 400 Rangefinder Logo
A
Anonymous Posted on Dec 17, 2013
How to read m100 optical tape measure - Ranging 400 Rangefinder
A friend gave me an optical tape measure ranging 600, I've never used one and don't understand quite what it's for or how. Not sure if it's for surveying or how to even go about using it.
It's for general purpose measurements. Usually, point it at a wall and press the measure button. It will indicate the distance from where you're standing to the wall. With a little practice, you'll be an expert and won't need to use a tape measure for the longer distances.
I have DCA analyzer from Siemens healthcare and i have problem E24 ,How Can Solve it
Manual is available in PDF format from here
http://docslide.us/download/link/dca-operators-guide
http://docslide.us/download/document/?id=%2FJKJQj2KkZIjS9Tn4Jm5CAbRibVv%2BGl%2BT9wi7I03ZyGSjZf8c1bXQnPy2%2FSc3BFIu8t3mvccp4VXj23OQyX8pQ%3D%3D
DCA Vantage Operator's Guide 109
Troubleshooting
E22 - Optical
reading is out
of range
A Sample or Reference
channel reading taken
during an Air
measurement is too
high.
1. Discard the sample.
2. Run an optical test.
3. If you are unable to run an
optical test, contact your local
technical support provider.
E23 -
Excessive
noise on the
Sample
channel
The standard deviation
of the 16 readings at the
Sample channel for Dark
or Air reading is too
large.
E24 -
Excessive
noise on the
Reference
channel
Reference channel for
Dark, Air or Sample
reading is too large.
E26 -
Excessive
noise in sample
reading
Sample channel during a
reading taken is too
large in Sample read
position.
E27 -
Excessive
Lamp Drift
The change in mean
signal between
successive Air readings
is too large at either the
Sample channel or the
Reference channel.
E30 - Thermal
control system
error - low
The temperature
measured by one of the
cartridge holder
thermistors is ?2?C.
2. Restart the system.
3. If you are unable to perform a
successful restart, contact
your local technical support
provider.
E
1helpful
Dear Sir We rely on an external contractor to backup our data. We need to retrieve the data and got this reply: " [...] I have just been down to the computer room and checked. Your data backup is...
these tape cartridges are very slow to read & write. if u r reading a set of data & need to go back for certain data u have to rewind & wait & watch until that data area arrives. it takes a lot of time. in order to save time u need optical disk drives & dvds to backup your data. u can also ask them to convert your tape cartridge data into optical disks.
2helpful
What indicates the black arrow mark in 16inches,32inches,64inches in steel measuring tape
Typical framing is laid out on 16 inch centers. Example: the studs in a framed wall are 16 inches apart which gives the required strength and allows drywall to break at a stud when it is installed. Drywall sheets are 8 foot or 12 foot, if the framing is on 16 inch centers then the drywall will end at a stud. The tape measure is highlighted at multiples of 16 inches to make it easy to mark the studs when laying out the framing.
MY TALKING TAPE KEEPS SAYING "ERROR. TAPE IS NOT IN". WHERE CAN I HAVE IT REPAIRED ?
Hi...problem with your Mesuring logic IC anonciator... take off your battery for reset...also check if your battery are low ...unit will fail to read correctly due to low battery....
1helpful
How to read steel tape?
Not enough info, a steel ruler could be in 64's of an inch, a steel tape measure is usually in 16's of an inch but some are in 32's of an inch until you get past the 12" mark.
4answers
Measuring Accuracy Problem
Use a second measuring tool and compare the results, or you can measure a known size or length (floor tiles for example)and check the reading you get.
Top Ranging Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Ranging Optic Expert? Answer questions, earn points and help others
