Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Sounds like a defrost timer.Also it can be a defrost thermostat.Try to adcance the defrost timer to a defrost and see if it melts the ice off.If so then i would say you need a defrost timer hope i helped:)
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
ok if compressor is running the you have a leak or restriction if frezeer is under five years old call the manufacture to get it fix but you have to be sure is running if is not running the it just might be the overload repl it and it will start again
