AV-56WP30 sound cuts out after about 10 minutes after turning the TV on. any ideas?
Hello
The audio output IC has some troube with it. if it overheat, the fault you describes here will coccur. Normally audio output IC will be screwed on to a metal heat sink to radiate heat away from it while working. If the screw that holds the IC to heatsink get loose, proper heat radiation won't take place, IC will overheat with time and will shut OFF by itself. Check the screw first. Resoder all the soldeer terminals of that IC, by applying a little more solder, without making any solder bridge in between the adjecent solder terminals. This process will eliminate if there is any loose soldering junctions to the terminals of that IC. If these does not help you, replace that IC with same type and number. OK.
