Question about Brother FAX 930 All-In-One Thermal Printer
Mfc1475pw/all in one/how to install
How to install to computer/if i cant install wifi now/do i need additional usb cord /do I need to install some type of program for my labtop to work through the all in one brother series
Posted by Diana Drake on
Ivan
    New Friend:
  • 52 Answers
I was looking for one hour some drivers, coudn`t find even on original website this model, try to install some different model, sometimes it works, sorry I can`t help you. Or you can download some portable program to find the driver, just download and unpack, turn on the printer and open this program
http://www.tactools.ru/iobit-driver-booster-pro-1-1-0-551-final-datecode-26-11-2013-portable/?utm_source=rss&utm_medium=rss&utm_campaign=iobit-driver-booster-pro-1-1-0-551-final-datecode-26-11-2013-portable
http://www.brother-usa.com/Support/Default.aspx?PGID=2#.UrCdobTCemp
Posted on Dec 17, 2013
2 Related Answers
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: what type of usb cord is needed for this printer
Hello there:
here is the information that you requested ok
I hope that this is very helpful for you
Best regards Michael
Cables for the Brother MFC-3220C 5-in-1 Color Multi-Function Center: corner1.gif Part# Price Status Qty. Belkin PRO USB 6' Cable
USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft F3U133-06 $8.99 In Stock Belkin 10' USB Cable
A/B Type, Hi-Speed USB 2.0, 10 ft F3U133-10 $14.99 In Stock Top
Posted on Nov 24, 2009
kywriter
Joe Haas
  • 25 Answers
SOURCE: do i need to use usb lead to install wifi on labtop use brother dcp j125
On most wifi printers, you need a USB cable to set it up the first time.
Posted on Aug 19, 2012
Can I print a document from my computer to a PIXMA MG2500 printer/copier
You need to buy a USB cable for your printer. Walmart has these cables.
Aug 18, 2016 | Canon PIXMA Office Equipment & Supplies
Wireless G USB Adapter
Hello there.
As you are getting this error message the best thing to do would be install the USB adapter with the latest drivers from the DLINK website.
Please click here . The website currently says its down for maintenance but if you check back shortly it should be working normally.
Hope this helps.
Jun 24, 2008 | Computers & Internet
Is hp pavillion 533c wifi ready
Nope. Most desktops are not equipped with wifi adapter. If you do not have a plan to buy a newer computer, you have to think about investing a few thing. If my calculations are right could cost you round 30$ to 40$.
2. USB extension cord (3 meters to 7 meters). This you will need to find good signal. 5$ to 10$25199670-hteicwtviizs0mofaamifrgr-5-1.jpg
3. If you don't have a USB port (which I don't see in the specs.), you need to buy pci USB card.
Caution to ask for "PCI USB expansion card".
Good luck, hope this helps.
Oct 08, 2014 | Computers & Internet
Can't connect using usb cable
Try using Ethernet. That is always the recommended way to connect to the modem, and it works almost 100% of the time without having to install additional software or perform any additional configuration. If you must use USB for some reason then you will need to make sure you have the drivers installed properly before connecting the modem to your computer.
Mar 31, 2014 | Siemens Speedstream 6520 Modem Router With...
Extending wifi
WiFi Router must be placed in higher position than users's computer. To get better signal, make an experiment with extended USB cable, and with additional USB Wireless adapter if needed.
Feb 12, 2014 | Computers & Internet
I bought my daughter an HP photosmart D110 Series printer for xmas. I set it up here at home using wireless, not USB, and it worked great. Now when she gets to her apartment which also has wireless, we...
start new,
use the D110 full setup instructions from scratch.
install the software from HP.
then on some printers, like mine, the USB way works or wifi
if you set it up to wifi , usb is dead.
and the reverse.
so must be reset , per the manual to get it the way you want.
it is a very complex device, this all in one e-printer
https://support.hp.com/us-en/product/HP-Photosmart-e-All-in-One-Printer-series---D110/4023244
wifi, is complex.
first the user must know the routers settings to make it connect.
but some times you have no access to that router, due to owners
are ISP or landlord.
to use wifi , i must force my router to use a fixed IP (reserved)
or will not connect , reliably, the manual covers this too.
use the HP install package,
rule 2:
NOTE: If the printer is connected with a USB or Ethernet cable, the printer cannot connect wirelessly.
click does not maintain wireless....., seen here.
it tells you to run the hp print and scan doctor there.
Aug 21, 2017 | HP Computers & Internet
My computer doesn't reconize my mp3
check if your usb cord if defective.
To check if the mp3 is recognized by the computer go to device manager in the compuer properties.
Go to device manager go to hardware tab and search for new hardware, if you see a question mark in the usb port it means that the computer cant recognize it and you may need a driver. Some mp3 have cd installer of its software. Install it in your computer. and try if the computer can recognize it.
also check if your usb port is working properly...
Sep 16, 2008 | Audio Players & Recorders
Emachine model T3302 desktop ethernet question
The "Realtek RTL 8139/810X family fast Ethernet NIC card" is a wired networking device. What you need is a WiFi Networking which can either be a PCI card (you need to open the PC and physically mount it inside) or perhaps the easiest, is to get a USB WiFi. There are so many brands, models and versions available and just about any would work. You need to verify though that the USB WiFi is compatible with your daughter PC's operating System (XP or Vista). Some known good brands are LinSys, DLink, NetGear. Some models/versions are simple gadgets that they look like a thumb/flash drive while others have a USB cable with a tabletop mount/rack/cradle.
Such can be bought from any computer shoppe/store. Most models come with an instruction/installer/driver CD that you need to run first before plugging in the WiFi USB.
If you already have an existing DSL account that connects to the Realtek, you would also need to get a Wireless AP/Router. It would probably be easier if you get a match pair (same brand)
If this is a completely new DSL WiFi setup, you need to get in touch with any WiFi Provider in your area. Most would provide a free USB WiFi Adapter if you subscribe to them so there would be no need to buy the USB WiFi adapter nor the Wireless AP/Router.
Hope this be of some help/idea. Pls post back how things turn out or should you need additional information.
Good luck and kind regards.
Jan 01, 2008 | E-Machines eMachines Desktop PC
My computer (PowerMac G4) doesn't communicate with my printer
Get an add-in USB PCI card.  My peripherals work on my G4.  These PCI cards will have 2.0 speed.
Nov 20, 2007 | HP PSC 750 All-In-One InkJet Printer
Brother FAX 930 All-In-One Thermal Printer Logo
70 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
