Question about Icon DVD100 -TV Car DVD Player Car Video Player
No sound Car dealership sold used vehicle w/ ICON DVD100 already in it, but we can't get sound. Is there a certain radio station? or a quick inexpensive fix
Posted by dimple25 on
  • Anonymous Oct 16, 2008
    no picture on one display (mine is in the headrests). I checked the cord and seems fine. Switched ports and no change
da_kine_inc2
    New Friend:
No sound and one of the monitor is not working
Posted on Jul 07, 2011
Anonymous
I generally use 88.9 to 89.7, I have had this problem in the past, what I had to do was pull the bottom device off of the Velcro and move it around untill the sound came in. But now I have another issue, the DVD player turns on but I don't get any picture or sound. It was working fine. any thoughts. Is there a way I can connect the display to my laptop?
Thanks
Scot
Posted on Sep 15, 2008
I have a 2007 suzuki forenza it was having battery problems so i replaced the battery and the alternator but my car still won't start.
It is standard practice with lots of modern cars to leave the ignition key in and turned to the on position when connecting a battery as this helps prevent alarms sounding, immobilisers engaging and all sorts of inconvenient stuff happening. It is even better to use a memory saver while changing a battery so not even the radio code and stations are lost.
You didn't say how long you have owned the car. If it was a recent purchase it should have been returned to the dealer as soon as you realised the battery was faulty. There is such a thing as warranty and consumer rights. The dealer certainly should not have sold the car with a defective seatbelt.
It certainly seems like the security system is activated though the presence of the key in the ignition should deactivate it if it is working ok so maybe it is broken or maybe it has forgotten the correct code and needs reprogramming.
It is possibly a coincidence and there is a fault, perhaps caused by the first mechanic. Before towing the car to the Suzuki dealer or calling for an autolocksmith it would be a good idea to physically check voltages, wiring, the presence of fuel and injection pulses, spark and suchlike. If all seems well under the bonnet the chances of an immobiliser malfunction are quite high. Reading the vehicle handbook is always a good place to begin.
Apr 01, 2017 | 2007 Suzuki Forenza Sedan
I get a picture but no sound. I bought the car with the dvd player already installed but no directions.
Hopefully you have a remote control for this unit. There is a FM select button. It's to turn on the FM modulator. When you press the button it will select different radio stations on the FM band. Once you select a station on the DVD, tune your vehicle radio station to the same and you will be able to hear the sound. Use this system to select the station with the best reception and less interference.
If no remote is available, there may be a FM button on the DVD player to perform the same function.
May 05, 2011 | Audiovox VOD102 Car DVD Player
I am looking for the owner's manual for my Icon DVD100 in-car dvd player. Are these available anywhere on-line? Thanks!
Any chance you have found the owner's manual for your Icon? I am also needing one and can not find one. Please let me know at [email protected] Thanks
Nov 18, 2010 | Icon DVD100 -TV Car DVD Player Car Video...
I boght the adapter tht conects my ipod to my car lighter so i can listen to it through the speakers but it wont play.is there a certain station i have to have it on?
Get your money back. There is no way to have something plug into the lighter plug and have it over take the radio or anything else for that matter. If you are wanting it to hook up to your head unit then get an aftermarket one unless you have a newer vehicle thats less than 5 yrs old and has that set up already. You will need one of two things, either a headphone cable that has male ends (like ones that are used for desktops to hook up speakers) and plug that into the the sat/usb/aux port on the radio or buy an adapter that will plug into an auxilary port on the radio.
Aug 11, 2010 | Car Audio & Video
Icon dvd100 tv player the print is mirrored backwards while playing
We have the tv dvd101T you can hit menu and when you cycle through past the contrast, brightness, etc mirror will be in there and you click it to off ( it is on right now). I'm sure yours works the same...Hope this helps!
Jul 13, 2010 | Icon DVD100 -TV Car DVD Player Car Video...
I need 2002 Acura 3.2 tl car radio code. The serial number is 30032270. Plz solve my problem.
Call your local ACURA dealership with your VIN number, if you bought the vehicle resale the dealership will be able to tell you where it was sold. Get the contact info for that dealer and call them, they should have the radio code on file, you may have to provide proof of ownership however you will have your stereo back. Good luck
Jan 31, 2010 | Car Audio & Video
Looking for replacement remote for my built-in car DVD player
Dvd remote replacement for factory installed DVD system. ITEM# 66-9L0
about $150
best thing to do is look in the vehicle again. It took me 3 times but I found it.
Mar 20, 2009 | Icon DVD100 -TV Car DVD Player Car Video...
No radio reception
check with the dealer tell them what is going on but my guess is it is the antenna is the issue
Nov 29, 2008 | 2005 Chevrolet TrailBlazer
I cant hear any am/fm station
try other antena or see solding points on the radio (open the radio and see the points of the antena)
May 04, 2007 | Koiiler XM-7590 Cassette Player
Icon DVD100 -TV Car DVD Player Car Video Player Logo
442 people viewed this question
Top Icon Car Audio & Video Experts
Marvin
Marvin
Are you an Icon Car Audio and Video Expert? Answer questions, earn points and help others
