Power shutdown after ll error
The LL error code indicates "Large Load Detected". If the load is not too large and you have taken some items out and it still comes up displaying the error code "LL" it may be caused from a friction issue. It could be the spinner support with bearing causing the code if it's creating enough friction. You did not indicate if it has any problems with draining water. If the washer is not able to drain completely it could also cause the "LL" error code.
