Question about New Era Denver Bronco hat : Denver Broncos On-Field Dog Ear 59FIFTY Fitted Performance Hat - Orange
Where can I find this item?
The New Era Denver Bronco dog ear hat is sold out on every website. Where can I find this item to purchase?
Posted by Georgia Bentley on
treeeee
    Master:
  • 519 Answers
shuyumeng
    Master:
  • 951 Answers
omers
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Dog ate the ear cushion on my AblePlanet NC180BMM Black Noise Canceling Headphones. Can I replace?
what --the dog or the head phones
the ear cushions may be difficult to get and it may be best to get new head phones
dogs you can get from the pound
Dec 12, 2016 | Audio Players & Recorders
What can I do to help prevent my dog from getting an ear infection? I clean his ears regularly; however he still seems to be getting infections.
I found a great natural remedy that works in preventing ear infections in dogs. I use it for my dogs and they have been ok for almost a year now.
THE FOLLOWING ALL NATURAL REMEDY
PREVENTS EAR INFECTIONS! This recipe is not meant to be used with Zymox. This should only be used once the ears are completely healed.
Keep in mind that it "will not" cure an existing ear infection.
Once you get your dog's ears to a healthy state either by using Zymox like we recommended or with the help of an antibiotic from your veterinarian, start using the following remedy weekly to prevent future infections. This works by raising the Ph level in the dogs ears.
Purchase an eye dropper bottle and the following ingredients
from your local pharmacy.
2 Tablespoons of Boric Acid
4 ounces of Rubbing Alcohol
1 Tablespoon of Glycerine
Shake the bottle before each use to thoroughly mix. Place a small eyedropper full into each ear. Cup the dog's ear and massage gently. Allow the dog to shake his head and gently blot dry any excess on the outside of the ear.
Do this weekly.
If ANY IRRITATION occurs - STOP using the recipe immediately!
Aug 15, 2012 | Pets - Others
Should I give my dog pigs ears?
I have read a lot of forums about this and it seems as though they are not that popular among dog owners. A lot of them say that the pigs' ears make their dogs sick with loose stools and others say that their vets have told them that pigs' ears are crawling with bacteria. So I wouldn't advise you to give them. Check out this forum: http://www.dogforums.com/dog-food-forum/951-pigs-ears-bad.html
May 13, 2012 | Dogs
Agitator problems..
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
Thank you for posting your model number. The part numbers you may need are as follows:
Item 10 - If just replacing the Agitator Dogs: 80040.
Item 9 - If replacing the entire Cam Assembly: 285809 (includes the Dogs and the Cam Thrust Bearing).
Item 22 - Spacer Thrust Bearing: 3951608
All these parts can be viewed under the "Agitator, Basket and Tub Parts" section of the parts resource websites I listed for you. The last digit of your model number is a "zero" (0), vice the letter "O".
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 26, 2010 | Whirlpool LSQ9030P Top Load Washer
I broke the plastic ear loop on my bluetooth. I
Depending on the manufacturer, they may not even sell just the loop. Go to their website and see if they list where their products are sold. Check ebay...
Mar 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Agitator wont go, have taken apart and believe the plastic teeth are all gone, how do we replace that and what is that part called
if your talking about the little dog ears at the top of your agitator under the cap ,those are easy to replace , they are called DOG EARS can get from your appliance shop or order from REPAIRCLINIC.COM
Feb 14, 2010 | Washing Machines
Is there somewhere I can find a diagram to remove the harmonic balancer on a 94 ford bronco
you can try autozones website, all you have to do is remove the belts, remove the fan and fan shroud,then remove pulley in front of balancer, then remove center bolt holding balancer, now use a puller to remove balancer, hats all good luck.
Nov 07, 2009 | 1994 Ford Bronco
1994 Bronco Egr valve doesnt fit into new ****** headers
They sold you a set of headers that don't accommodate the EGR valve line. You can buy headers that have the bung welded into them for the connection. If you do not connect the EGR then you exhaust gas temps will run high and pinging will likely be the result. Excessive preignition can cause valve and piston damage. The lack of the EGR valve may cause you to not pass your states emissions test. I would purchase a set of headers that have the hook up on them. Try Gibson headers. They sell these.
Feb 17, 2009 | 1994 Ford Bronco
Teach & talk activity laptop by Blue hat Toy Company
I sent an email to [email protected] which is customer service for Blue Hat Toy Company. She emailed me a PDF file manual for the Teach and Talk Laptop. Without the manual you would never be able to get the game functions figured out.....
If you need the manual I would be happy to forward the pdf file to you.
Becky
[email protected]
Oct 21, 2008 | Blue Hat Teach and Talk Activity Laptop
New Era Denver Bronco hat : Denver Broncos On-Field Dog Ear 59FIFTY Fitted Performance Hat - Orange Logo
618 people viewed this question
Top New Era Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a New Era Clothing Accessory Expert? Answer questions, earn points and help others
