Question about Garmin StreetPilot c550 GPS Receiver
Garmin c550 LCD Screen Faded Out
I can no longer read my LCD Screen.  I have seen multiple blogs reporting this problem happening from the first day of purchase forward.  Is Garmin recalling this model to correct feature?  This product is made to use in a car yet I am being told not to leave it in direct sunlight or heat and to make sure my a/c is blowing on it.  How can I do this and still use it as a GPS?  Please help!!!!!!!!!
Posted by 2fast4u on
Anonymous
    Novelist:
  • 113 Answers
Try tapping the power key while the unit is on.  This may activate a control for contrast and brightness.  Otherwise it's in the settings screen.  Try looking at the screen in bright sunlight it may be make the screen visible enought to see the settings.
The unit will withstand the same heat that a human body can withstand so you can use with no problems while you are driving.  Don't leave it on the dash when you are not using the vehicle as the extremely high temps that occur in a stationary vehicle with the windows rolled up will damage the unit.  It is very easy to place the unit where it is not in the path of air conditioning.
Posted on Oct 26, 2007
I would like to up date the lateest maps for my c550
Maps are available for purchase either at Garmin's web site, or from your local GPS retailer. Garmin now offers a lifetime map update for one price, which allows you up to 4 map updates per year.
Mar 16, 2009 | Garmin StreetPilot c550 GPS Receiver
My Garmin c550 will not come on anymore. The screeen is black
Check the 12v power cord to make sure its still powering/charging the unit. Usually they have a light on them that will show if its receiving power or not. You can also unscrew the tip of those things (on most cables) and check the fuse to see if its blown. If its not lighting up and the fuse on the cable is ok check the one in your truck to see if it needs replacing.
If the cable is not the issue then the GPS is probably dead. If its not under warranty the flat rate repair fee from Garmin is $200
http://www8.garmin.com/support/outofwarranty.html
Jan 18, 2009 | Garmin StreetPilot c550 GPS Receiver
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
just model number is different but the system is same
hope this helps
Nov 25, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin c550 phone book problem
Try deleting the pair from both the phone and the Garmin.
Then, retry the pairing sequence.
Hope this helps.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Entering street names
The Garmin may not recognize the street name you are entering due to a scroll error. When you type, it constantly looks up streets beginning with the letters you already entered. If you happen to hit a wrong letter, it automatically errors out. Have you updated the unit recently? If not try that first.
Load USB drivers to PC (if not done already), connect Garmin, turn Garmin on, run webupdater, follow on screen prompts.
Jul 15, 2008 | Garmin StreetPilot c550 GPS Receiver
Won't turn on after first time
saw this on a different forum.....I got one for xmass.....hope it doesn't happen to me!!!!!!!!
I apologize for the inconvenience. After further research with our engineers, a problem has been discovered on your C550. A file has been created to stop the unit from turning off and locking up. Please download the new file from your computer to the unit. The file is attached to this email along with instructions on how to get the file into the unit.
The following procedure will update the software in your C550 series and correct the power issue you are experiencing with your Garmin C550 series
1.) Let the Garmin sit without power for at least 24-48 hours.
2.) Plug the C5xx series into the your computer (using a USB port in the back of the computer) with the cable provided with the unit.
3.) After removing the faceplate on the front of the Garmin press and release the reset button. At this time the C550 series will reset and power on.
4.) Save the attached file included in e-mail from Garmin Product Support. Save this file to the desk top on your computer. Note: This will make it easy to find.
5.) Open the My Computer window (by accessing the start menu on the bottom left of your computer screen).
6.) Locate and open the Garmin Mass Storage device.
7.) Locate the Garmin folder and open.
8.) Open the remoteSW folder.
9.) Copy the file that you have saved to the desktop and paste it into the remoteSW folder you have just opened. Make sure that none of the files contained within the remoteSW folder is highlighted, or you will not be able to save the new file.
10.) A message window will pop up asking you to confirm that you want to replace the file; Select Yes.
11.) Disconnect the C550 series from the USB cable and let the unit restart. A message will appear on the screen stating "Updating PLD Software".
Note: the screen will fade out and go blank during this process. Do not be alarmed, this is part of the update procedure, and the screen will return to normal within seconds.
Dec 26, 2007 | Garmin StreetPilot c550 GPS Receiver
Dec 06, 2007 | Garmin StreetPilot c550 GPS Receiver
Screen Image too light to read
Oct 14, 2007 | Garmin StreetPilot c550 GPS Receiver
GARMIN C550
Hi Don,
You probably just need to find the reciept where you bought the C550.  Sounds like Garmin is protecting its customers when they say $300.  This is most unfortunate thing to happen to you.  Is the Garmin $300 issue as I thought and related to you not having the registration code or Reciept?
Oct 13, 2007 | Garmin StreetPilot c550 GPS Receiver
Screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Oct 05, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
129 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
