I need drivers for the R5 230 graphics card that are for windows xp not vista
SOURCE: Coloured And Dotted Lines Across My Screen
Firstly, start your pc in safe mode (f8) on boot up. This will start your pc in vga mode, and hopefully the lines are still there, which will indicate a faulty graphics card, if they aren't it may be a problem driver. If no lines, go to Add/remove programmes and uninstal your graphics driver. Re boot pc then when it finds your card make sure you point Windows to the folder in which you have saved the driver files. The driver should then install, see if any change. You may have to try some older drivers, as Nvidia can be awkward at times. I have had varying problems with Nvidia and replaced with ATI cards with no problems.
SOURCE: Graphics card drivers
Yes, right-click on My Computer>Properties>Hardware tab and Device Manager. Find your graphics card in the list. Click on the "+" sign to get your model. RIght click on your model. Click on update driver to make sure you have the latest driver. Also, there is a Troubleshooting tab. If that is OK, then go back to Control Panel. Click on Power Options. Set Sleep and Hibernation to how you want them.
Please rate this solution.
SOURCE: nvidia geforce9400gt monitor problem
Usually the problem with windows 7. if you have 2cables connecting from youre monitor to the graphics card, unplug one of them, it worked for another guy
SOURCE: screen went dead, unplugged the graphics card and
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4.
Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set
the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6.
Check the powersupply function. Either by a powersupply voltage
checker, put the powersupply in a different pc, or try a different
powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
If the video card is suspected to be damaged, try it in a other pc (friend's, mom's or dad's, pentagons' ).
if it is bad, there is your answer.
SOURCE: Code 12
Try entering this command "bcdedit /set CONFIGACCESSPOLICY DISALLOWMMCONFIG". If it doesn't help, you can reverse the change with this command: "bcdedit /set CONFIGACCESSPOLICY default"
