If replacing the control panel is the solution, that assumes:
1. A GE-authorized repair tech will actually show up to do the swap, or you can do it yourself without voiding any remaining warranty clauses....and
2. The replacement control panel doesn't have the same defect as the original.
Has anyone been able to isolate the fault within the Control Panel? Why no GE recall on this item?
While reading everyones comments I'd like to open my back door & scream very loudly and throw the ADVANTIUM with it. We just replaced the control card and it worked for approx 2weeks and tonight in prepperation for Thanksgiving it gives me a great BIG F3. I quess the day after Thanksgiving I wont be Holiday shopping I'll be buying new Oven And not a GE
This is due to a Defective control board..You have to get it replaced..
Beeper won't go off and it displays F3 code
Mine is approximatly one year old...just off warrranty. The repairman states it is a defective touchpad/control board. He stated that he has repaired many of these and that theeey are a problem on GE appliances. Sorry.
I have the same problem with my Advantium 240and it is very annoying.
Sometimes you can get the F# to go away by touching the cancel pad, but
it appears back after a few minutes. My oven is less than 2 months old.
For GE to be using these poor quality controls boards in an appliance
this expensive, is pathetic! Just like GE to do something like this.
Wish I had never bought this GE Advantium and stuck with a better brand.
My Advantium profile oven is only 10 months old and the F3 error message keeps appearing. My wife turned off the sound for the oven and pushed buttons until the message went away and that only worked for about a week and then it has started again. It continues to beep as I type this and it is quite annoying. Thanks GE. I thought your slogan was "you bring good things to life". The constant beeping is not so good.
F3 error message keep coming up, lots of beeping, advantium is less than 1 year in use.
Our brand new GE Profile Advantium has been used gently for only three weeks. This appliance apparently does not like us and retaliated by flashing the dreaded f3 error code and beeping relentlessly all night long until we figured out how to cut off its power source at the breaker box, which was apparently mislabled. We nearly turned off the refrigerator by mistake. Isn't this supposed to be a top end appliance? Calling GE repair now and eating cold breakfast.
Same problem after 5 months of use. F3, constant beeping. Was part of a GE Profile Double oven. Unfortunately, both are on the same CB, so I had to kill both ovens to stop the noise until the Warranty service folks could arrive....
...Except for the fact that none of the GE-authorized service providers will touch a warranty service call on this oven. They generally cited GE's bad reputation for paying service call claims in a timely fashion. After 3 months without an oven, GE finally cut us a check to replace the oven. Of course GE then found a way to get a GE-authorized service provider to come out and pick the damn thing up. Now I have an Advantium-sized hole in my cabinetry and a check for the cost of the now-gone oven (note: check does not include cost to ship or install a new one).
Mine is a couple years old and just started this behavior. On the advice of my salesperson, I cut the power for 20 minutes. When it came back, I tried to set the clock but couldn't. The dial would let me change the hour but then I couldn't push the dial to set the hour and select minutes. Not it is back to the annoying beeping/f3 message.
Does anyone know approx how much a new control pad costs and how hard it would be to replace one myself? I am already out of warranty so what the heck.
Our Advantium SCB2001KSS02 (mfg date Jan 2007 and installed July 2007) started the F3 error+beeps last night at 2:30am. Powered off and restarted in the morning...now locked up and DEAD. Will advise situation after the repair (which is 1 week away). GE usually does not bring the correct parts to fix the problem then we're down for another week or more. This is the first problem for this Advantium, but it seems all GE Profile units (except vent hoods) have some problem during the first year.
me too
My oven was in use for 11/2 years before the dreaded F3 code and of course is now out of warranty. I am extremely angry over this. You would think that a product of this expense would be a better quality appliance. I am also wondering why there has been no recall on this defect. I had a similar circuit board problem with a 13 month old Maytag refrigerator which if I hadn't called to complain would never have found out that the board was defective and they sent me a new one. They also were not letting the public know of this defect. Where is the consumer protection?
I have the same problem. Last night at 11pm my GE profile started to beep and the displayed showed a "F3". I pressed clear and the error message went away until about an hour later when I awoke to hear more beeping. Like most everyone with the same problem, the only solution is to go to the breaker box and turn the circuit off.
Hase anyone had sucess with GE, that has an extended warranty?
as soon as oven reaches desired temp, it starts beeping and displaying codes F3 or F4.
