Question about Philips Magnavox DVD/VCR Dual Player
DVD player wont show picture
I need to know how to get the progressive scan feature turned off so I can view DVD's.
Magnavox DVD/VCR combo    MDV560VR
Posted by sally86 on
  • 14 more comments
  • Anonymous Nov 07, 2007
    I JUST DO NOT KNOW HOW TO TURN PROGRESSIVE SCAN OFF
  • Anonymous Nov 22, 2007
    Cant turn off Progressive Scan, It kinda sucks.
  • bigwill4real Nov 30, 2007
    The progressive scan feature will not allow my DVD's to play.
  • 89kinds Dec 16, 2007
    Can not get Progressive Scan to turn off!
  • bunty_ak Dec 28, 2007
    cant turn off the progressive scan on my dv 366
  • Anonymous Dec 31, 2007
    GoVideo DV1130 DVD Player / VCR Combo
  • bassilio Jan 03, 2008
    how to stop the progrssive scan on pioneer dv-275-s ?
  • Anonymous Jan 03, 2008
    I need to know how to turn progressive scan off
  • Anonymous Jan 04, 2008
  • Anonymous Mar 06, 2008
  • Dharahombe Mar 10, 2008
    LG DVD PLAYER
  • rena32681 Mar 15, 2008
    The progressive scan is turned on and now i cant view anything with dvd player. I cant even view the menu so that i can get it turned off. How do I do this?
  • Anonymous Mar 29, 2008
    i have the same problem with the progressive scan
  • Anonymous May 04, 2008
    can't take the progressive scan off, How do we fix it?
  • ramyaraj Aug 17, 2008
    AFTER INSERTTING THE DISC ITS SHOWING 'NO DISC ' INSIDE...WHAT TO DO
  • Richard Neely
    Richard Neely Nov 02, 2013
    the is a sony SLV-D300P
Anonymous
Take the dvd out and hold the stop button on the dvd player for 5 sec (not the remote) the dvd player and that will work
Posted on May 20, 2008
  • gacheva Dec 03, 2010
    Yes, this did the trick. Thank you very much for your help. Gacheva
Anonymous
I tried this and it dodn't work. the way i fixed it was a button on the remote that said p. scan. thanks anyway,
Posted on Mar 29, 2008
Anonymous
I searched forever to fix this, it darn near drove me insane... http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&session=20071221020919_75.82.190.84&slg=AEN&refnr=0016098&refdisplay=AVS_DVP_011&dct=QAC&ctn=DVD622/37B
All you have to do is eject the dvd drive to open and hold down the number one on the remote. Hope this helps your sanity!!
Posted on Dec 21, 2007
1 Related Answer
james klgr
james kilgore
  • 362 Answers
SOURCE: DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Posted on Dec 09, 2007
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Feb 05, 2009 | Toshiba SD-V392 DVD Player/VCR
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan mode
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Have sound,no picture
Do you have it hooked up using the component cables?(red, blue, green cables?) You need to use the component cables to use the progressive scan feature. So if you have it hooked up using the yellow rca jack, you will have to switch cables.
May 30, 2008 | GoVideo Go Video DVD/VCR Combo
Thanks for the progressive scan advice. I have a Go-Video DV1130 Combo I didnt have a DVD in the combo and I pressed and held the stop button on the combo instead of the remote and it came out of the progressive scan mode so maybe it works both ways? But anyway Thanks for the advice it sure helped me.
Dec 31, 2007 | GoVideo DV1130 DVD Player/VCR
Issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Thanks!
Patsy
Dec 29, 2007 | Goldstar GBV241 DVD Player/VCR
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
1,323 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
