TV is asking "Please run channel scan." How do I do this.
Channel scan is nothing, but an auto-tuning. Refer its user manual for details.
Posted on Dec 17, 2013
SOURCE: Please scan channels
try hitting the input button or go to channel 3. the sat box can only output to channel 3 or 4 or if using Dish network try channel 66 or what ever the channel it outputs. it also can output via video cables so check each video setting on the set. make sure the box is on first.
Posted on Jan 17, 2008
SOURCE: Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Posted on Mar 20, 2008
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
SOURCE: My tv keeps saying to run auto channel scan.
FIRST, you must check ALL antenna connection, and if possible, try another "Known Good" antenna system. If it proves that the antenna system is all OK, then I fear your Tuner, has failed, this is a common event, that I get from time to time at my shop. Usually, it is a straight forward job and the cost would be about $250 - $350, depending exactly what is going on. However it would be best to get a "Quote" first, before proceeding, as this may only be a symptom, of a larger underlying problem, that may indeed cost much more.
Posted on May 23, 2010
