Question about NetGear DG834G Router
Unable to connect my hudl to my provider plusnet can get past authentication
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
How do I transfer photos from my computer to my Hudl 2?
Hi. To transfer your photos from your computer to your Hudl 2, connect you charging cable to your computer. Make sure that your Hudl 2 is show under the 'My Computer' page of your folder section. Then select your phots and drag the into the Photos folder of you Hudl 2. This can be found by double tapping the Hudl 2 icon on your pc.
I hope this helped.
Aug 23, 2015 | Tablets & eReaders
Using plusnet router TG582n unable to get Internet on Sony TV
Is router LIVE / Connected, check signal . you need to contact Plusnet HELP Dept ,
l
Mar 15, 2015 | Gateway Computers & Internet
Where is the the recharging button om my hudl 1
Hi Robert,
You should just be able to plug your HUDL in and it should begin charging. Check that the outlet you're using is providing power (try another outlet too).
I'd recommend getting in touch with Hudl directly should you need additional support, I've included their support page below:
Get the Support You Need
Hope this helps!
Feb 27, 2015 | Computers & Internet
Low sound volume using with hudl
perhaps you have the speakers connected to the wrong connector on the hudl
Feb 28, 2014 | Labtec Audio Players & Recorders
I used to use Thunderbird. and have a heap of emails stuck in there and am unable to fwd them back to myself into yahoo.xtra. Keep getting the message ''An error occured sending mail unable to authenticate...
just disconnect the internet connection and close the thunder bird application and start it again and then go to configure setting and change the setting.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | Computers & Internet
Alcatel Speed Touch PCI Modem doesn't work on my Win 98
Windows 98 0r 98se are no longer supported by any kind of internet service providers anymore only windows 2000 and newer. hope this helps.
Aug 10, 2009 | Alcatel Speed Touch Modem
Since changing internet service providers from homecall to plusnet, i have not been able to connect to the internet on my wireless router what can i do????
this might be a silly question but i presume you've changed your router's settings from using your homecall account to using your plusnet account?
Aug 10, 2008 | Computers & Internet
Setting up for broadband
First, you might want to check with Plusnet the login information and the type of the authentication they have. Secondly, setup your router, login to your router using a web browser. Type 10.1.1.1 in the address bar and press enter key.Login using the default setting username 'admin' and password 'admin'.
Click on Home tab and then on WAN on the left side of the screen.Select PPPoE/PPPoA option.Under Connection Type select 'PPPoE LLC' in the drop-down menu.Enter username and your password.Please check with your provider if not sure again.
If you have connection with static IP address, you do not have to specify the IP settings on the router: the router will be getting the same IP from your ISP every time it connects.Click on Apply. To save the settings into the router's memory go to Tools > [System] > Save and Reboot.Give the router a minute or two to reboot and reconnect.
Lastly, Restart your computer and you should be able to access the Internet.You do not have to run any login client on any of your computers because your router logs to your ISP automatically.
or check this URL;
ftp://files.dlink.com.au/products/DSL-502T-GenII/Manuals/DSL-502T_GenII_Manual.pdf
Jun 12, 2008 | Computers & Internet
NetGear DG834G Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
